C
Chandreshwar Gupta Posted on Nov 23, 2015
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured
  • FRAMELESS1
    FRAMELESS1 Feb 23, 2016
    some sensor problem.
FRAMELESS1
Level 1:
New Friend:
  • Contributor 6 Answers
  • Posted on Feb 23, 2016
FRAMELESS1
Contributor
Level 1:
New Friend:
Answers
6
Questions
0
Helped
11884
Points
17
Clear the paper jam. If theproblem still continues after clearing the paper jam, try to clean the encoder strip behind theprinter head
LukasCY
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Nov 30, 2015
LukasCY
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
12703
Points
13
Clean 50 is either Dirty Encoder Stripe or broken Maintenance Unit. In first case clean thoroughly the vertical Encoder Stripe and it should work. In case 2 better exchange the machine
How to reset unable to clean 50 error on brother dcp-j125? I cant open my printer brother dcp-j125 due to an error unable to clean 50.no paper jam occured.
You need to pres Menu-Mono Start-Up Arrow 4 times in less than 2 Seconds !!! and you will be in Maintenance mode. LEDs will be flashing. Press the Up Arrow and numbers will change and press OK after the one you want to select. The number sequence is the following. 8-0 2-8-6-4 4-4-6-0 7-7 9-9
Brother error code dcp-j 125 unable to Init 50
hi good day! the printer is error 50 due to a paper or some sensor error.. open the printer, or dismantle, clean the sensor and wash the pump of water and change the waste pad of new absorber. locate the sensor under the pump, clean it of alcohol.
1helpful
Unable to init 50
paper jam or some sensor error, try to clean the sensor located at under the pump.
62helpful
4answers
18helpful
3answers
My brother DCP-165C clean unable 50 problem, i can not use my printer due to this problem, what am i gonna do' pls. help?
my brother DCP-165C clean unable 50 problem, i can not use my printer due to this problem, what am i gonna do' pls. help?
21helpful
3answers
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Norman Weimar
Norman Weimar
k24674
