Trying to program my comcast remote to operate yamaha. Codes for yamah don't work
SOURCE: Codes for Yamaha HTR-5240
just go here and download the manual...
http://www.usersmanualguide.com/yamaha_audio/av_receivers/htr-5240
it has all the codes listed
Do a code search from comcast. If you have the Comcast manual it shows you how to search for codes manually, it can take 15 to 20 minutes for you to do it, however, it should fid your code. The only drawback is that you can only control the volume and power, you won't have input or soundfield control. Hope this helps
SOURCE: Need a code for my Comcast Universal Remote
30176 is the code you need . Press Aux and then hold setup until Aux lights up. Enter code. If you want the remote to control the receiver all the time, press Aux and then hold setup until Aux lights up. Enter 993 then press Aux. Aux will flash, now press Cbl and Aux should light up when you use the volume.
SOURCE: comcast remote
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
SOURCE: Need yamaha codes to program into uverse tv ir remote
I have the Yamaha V371 receiver and Uverse code 5167 worked on the BLACK (not grey) Uverse remote
