Why can't I raise or lower the deck?
Sounds like you have jammed linkages which raise and lower deck, you can try this which usually works best with assistant.
With engine off, shake the deck vigorously (up,down, back and forth) while try to raise deck with lever.
Check for worn or damaged arms, springs, deck mounting points, etc and repair or replace.
