If the leak is from the bottom of the front door than it is most likely the door seal. If the leak is from beneath the unit and appearing to leak out from the front there are many sources for the water.
Check the seal around the door. It may have some residue that has collected prohibiting the seal. The water in the machine actually sits in a tub. The seal on the door prohibits the water leaking as the spray arm rotates.
To test the door seal start the cycle and stop the unit as soon as the machine begins the spray cycle. Open the door and observe that the tub is full but still below the edge. Dry the seal around the door. Place colored paper towels or cloth beneath the door as close to the door seal as possible, Continue with the cycle and observe for water leaks. Stop allow the unit to sit a few seconds open door and observe the seal. You are looking for the location that it is leaking.
If you can confirm that the seal is leaking you can purchase replacement seals, On some models they can be easily replaced.
In my experience I have not seen a filter in the return line. If there is a blocked return hose the unit would not leak. The tub would remain filled after the cycle. There is an overflow switch that prohibits the tub from overfilling if the tub has not emptied between cycles.
