No power
If you mean absolutely no juice and haven't done so already, you need to check the breaker or fuse first. If the breaker/fuse is off flip the switch and try the oven. If the fuse trips again, you have a short someplace.
Obvious places would be the cord and outlet. To check these, turn the power off again and pull the stove out. Follow the cord and check it for broken areas areas. Then look at where it connects to the stove. Check the outlet and make sure that is intact.
If you see no problems with the outlet, the easiest way to check it without a tester is to simply plug another device into it.
