BSOD, the black screens of ***** (my fav)
old CQ56-nnnnn, no full model stated of many.
cq56-105SE , is one, what is yours, off the
service TAG????????
there are 10 in the series , which one>?
https://support.hp.com/us-en/products/laptops/compaq-notebooks
NO OS stated, is this XP/vista/w7/8/10?? must we
guess that?
1/2 the PC is the OS !
those caps keys blink a code, not stated by you, only blinks.
what code, is important to any HP diagnosis
it means hard failures. (bad chips, bad hdd, overheated or? RAM bad?)
"nor does heat of any kind" what does that mean, I hope to deity
you dont use and oven or heat gun to heat it up. ever.
heat is the killler of all electronics (lightening #2 (& ESD)
#3 floods.
my guess you ment PC fails hot and old, naturally.
dead cold or let it sit failed self warmed up, it fails.
ok, Ill run with that.
that code for CPU is wrong. I bet.
the codes are supper complex, by year. changed vast times.
guessing is bad. here,
what if the code meant RAM bad.
here ill will attempt to find what BIOS is there (for codes)
by age. 2008 it seem or tad newer , first is 2008 .CG56-100
not knowing real modle number and age is a FAILED post here.
2010 every code changed, (a fact) so I will answer for 2010 year.
only, (just to show I can do it)
did you know the older Pheonix BIOS had up to 50 codes!
yah !
BSOD black 101:
- run on AC ok with the bad shorted battery main out? be 1st!
- the code what was it, why not tell the code? now.
- did you know the CMOS coin cell is dead, code 2 (2010) as all are this old (99% true so, measure it?)
- fan spins and not packed in lint as all are 7 years later.
- Do the BIOS screens work? F10 key hammered power on.
- If BIOS runs does it keep TIME AND DATE? see #3 above.
- does the PC boot and run on a Linux CD or usb stick?
- do the BIOS memory tests pass?
- do the BIOS HDD tests pass?
- are there any words ever (text) on the screen ever or logos ever. y/n, if no the pc may have bad CCFL lamps.
- Does the F11 key hammered at power on, work? shows the HP offical recovery page?
- more tests, when the code is told. (blink codes MATTER)
from your service manual
It tells you (9 years it showed this on screen) ever day ...
Open the Setup Utility by turning on or restarting the computer.
While the "
Press the ESC key for Startup Menu" message is displayed in the lower-left corner of the screen, press f10
if the screen is dead,? totally.
2010; list
1= cpu bad or overheated !
2= CMOS battery dead (Cmos ram fails check sum checks due to Battery is now DEAD, 2-5years old is par on batteries. 10 super max life.(pure luck there)
3=memory
4= GPU bad or overeated!
5= mobo failure, (bad bad news)
6= bios authentication error (my guess, bios password errors)
6 is UEFI, and only on the most new PC's
the blink codes are key to all PCs made, what was it
and matching that to your EXACT BIOS version
guessing codes is useless, there are vast codes used.
my guess maybe 20 books in 20 years of this PC.Maker. only
HP skips older than 2010 so is a pain. if is.
i google this and landed here, for compaq, (old)
http://h20628.www2.hp.com/km-ext/content-webapp/document?docId=emr_na-c01732674
i think that is a match, and seems a hidden legacy page inside, HP. nice.
the blinks are POST catastropic errors, and must be addressed first.
