It is just tinted green, but it turned a really lime green color. The TV is on all night and most of the day. I think it is a color tube. What should I do? And should I have it off or is it fine? The tinted darker green has been off and on for 2 -3 years. The lime green just was once but I am afraid it will happen again.
SOURCE: Blue Tint
Most likely cause would be a loose solder connection that expands as the set warms up until it no longer makes a connection. You may get the blue to come and go by hitting the side of the cabinet after the set is warmed up awhile. (don't hurt your hand doing this, and don't keep doing it to "fix" the set. The connection will have to be located and repaired). Otherwise, there could be a component going bad, including the blue picture tube.
SOURCE: Sanyo Tv color problem
Hello, The TV is four years old. About two weeks ago the screen suddenly had a complete red tint. I tried adjusting the color settings but nothing really improved. the next time I turned it on, it was fine. But the time after that it turned red again. Now it more and more often has a deep red tint. Any advice? Thanks please do not adjust any thing. your problem is in red color cathode ckt it might be loose contact in red cathode. crt base might be loose. check red output supply. signal line from chroma ic to crt base. regards thanks
SOURCE: Negative type images in pink & lime green
I had the same problem....turned out it was the "lvds" cable that runs from the mainboard to the lcd controller board. Simply remove the tape that holds it to the back of the backlight housing and also remove the foil shielding tape from the connector on the lcd controller board.
SOURCE: Sony KV-36FV27 too dark, pink or green tint, 5 blink error,
Fuzzy,blury picture in CRT tv tube.Tv in long use not repairable.Tv tube is dying,it junk.
