Tip & How-To about Fuel Line & Primer Bulb Repair Kits 2 Cycle Fuel Line Repair Kit For Chainsaws Snow Blowers Weedeaters And For All Makes And Models Of 2 Cycle Equipment. Fits Poulan Craftsman Snapper Homelite Ryobi Idc Featherlite Robins Husquvarna Weedeater Mtd John Deere And More
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
