GE WSM2420T Top Load Stacked Washer / Dryer Logo
s
steve fangmeier Posted on Nov 17, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When starting the spin cycle it will not spin until I push the knob in and pull it back out. It will then go through the rest of the spin cycle.
It does pump the water out without spinning.
Sean Piquet
Level 3:
  • Master 1,867 Answers
  • Posted on Nov 17, 2015
Sean  Piquet
Master
Level 3:
Answers
1867
Questions
Helped
610335
Points
7259
To fix that you would need to fit a new control board on the machine. Probably not worth the cost though.
1helpful
Sometimes starting the spin cycle it will not spin until I push the knob in and pull out again.
Timer stops intermittently during spin cycle
When it stops try wiggling the timer knob if you get it to start most likely have a timer problem not connecting inside the timer. Hope this helps
How do i replace a programm switch on a simpson 750 esprit washing machine
Normally, you would push in on the knob to set to a cycle then pull out on knob to start machine. Am i correct? So when you push in to set the cycle it just spins?
1helpful
Machine won't Agitate
timer bad easy fix.
I filled my washing machine with clothes tonight and it got to the end of the short cold wash cycle and had stopped running so I pushed in the knob then pulled it back out and then pushed it back in and...
It sounds as if the machine doesn't spin during the spin cycle. Normally the agitator stops spinning, fairly quickly, if the lid is opened during the spin cycle.That safety circuit includes a switch mounted under the opening and is set by a tab on the lid that protrudes thru a small hole in the top of the washer. The most likely failure on most Kenmore models is that switch, broken or loose, the tab on the lid broken, or the two misaligned. I would need the model number of your washer, located on a tag on the bottom of the lid to be more specific
2helpful
2answers
Kenmore Elite Washer Does Not Spin
This a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.20992991
and you'll see a list of major sub-components with diagrams and parts.
The brake on these washers is driven by the clutch on top of the transmission.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
This is a Whirlpool PDF on how these washers operate. It has a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
If the washer drains the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again or stopping and starting the cycle knob, and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, or stopping and starting the washer torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
1helpful
Maytag washer stops during spin cycle
it seems like aproblem w motor maybe need to acouple of new carbon brush to fit in motor
i think that because it seems to me from your words that the motor only works w no load
thanks
Timer knob spins when pushed in. unable to set wash cycles
If you suspect you have a defective timer it can easily be replaced by performing the following steps:
1. Unplug washing machine... and pull out the timer knob. Some knobs have a removeable center cap and hidden screw. Some are simply slip-fit. Remove the knob.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer.
The cap will pull off towards you as you are facing the unit from the front of the washer.
There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up.
There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Disconnect all power plugs and remove the timer's mounting screws.
5. Reinstall reverse of removal.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Kenmore 70 series won't spin but will drain
This is joyce
It is your switch in the lid, replace it you should be fine, how old is this machine? if this is not it go to kenmorel.com and get your manuel and try to get some help with your machine their. or I can help call a technician in your area let me know.
thanks
joyce
Washer stopped in the middle of the cycle
sounds like motor if nothing stuck between tubs or in pump ,check these first if ok you have bad timer
Top GE Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Virgil Watts
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
