SOURCE: brand new cordless handset -- no dial tone, no ring!
I doubt it's the battery. As I understand it the base works fine and the problem is only with a cordless phone. Are you using an external charger stand for the cordless handset? These phones need to be registered to the base unit. That is usually done by installing the cordless phone in the base unit but you may need to do that shortly after insalling the battery or you could have a register button or setting.
SOURCE: Out of range
I successfully reset Radio Shack (Uniden) 5561 handset by reconnecting the battery while holding the '*' and '#' key, then press the right upper soft key near the LCD window. The display will indicate "EEPROM/RAM cleared!!" and will return the handset to the factory default condition - looking for a base to register to.
SOURCE: out of range shows on main handset of cordless phone
Unplug the battery. Hold down The * (star) and the #(hash) keys simultaneously. Re-connect the battery, phone will beep and screen will be blank. Press the voicemail (righthand silver key under the lcd screen). As above EEPROM/RAM message will appear. Place handset on base and your problem is solved.
SOURCE: ADDING HANDSET SAYS OUT OF RANGE
A search of Uniden support only said to call 1-800-297-1023 with handset registration issues. The rep picked up quickly and walked me through the reset procedure. Here it is step-by-step:
1. Remove battery
2. Hold down the * and # buttons and reinsert battery. You should hear a long beep. If not retry. (This is a bit awkward but hold the handset upside down and it's workable)
3. Screen will be blank. Immediately press the right soft menu button.
4. Screen will report that EEPROM is clearing and then state EEPROM Clear Ok
5. Remove battery (yes again)
6. Reinsert battery (this time there's no need to hold down any buttons)
7. Handset will reboot with Welcome screen and then state that phone must be registered (this is the status a handset should be in from the factory)
8. Place handset on base and it will register as normal
