How to open batterer case?
I don't know about this specific model of Braun shaver (I have a Braun Model 7526).
I have looked at the instructions for a couple of models of Braun Shaver, and the instructions are similar so it may help you to replace the batteries in yours.
Here is one of the instructions:
Braun 7526 battery problem
http://www.fixya.com/support/t1171024-braun_7526_battery_problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 screws
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
And here is a link to instructions for a few different ones:
http://www.fixya.com/support/t1094906-needs_new_batters_open_razor_7526
http://www.fixya.com/support/t6710169-change_battery_cost
http://www.fixya.com/support/t771258-braun_battery_replacement
I have changed the batteries on my Brain 8995 shaver. The batteries are not just clicked in as in a torch but are soldered to small terminals. So knowledge of de-soldering and re-soldering is needed. The 2 original batteries are also held in place with a small amount of rubberised glue so they need to be prised off gently. After fitting the new batteries I used a tiny amount of Superglue to secure them.
New re-chargeable batteries must be the same rating of course.
What is the specific model number?
