Microwave Ovens Logo
J
John Posted on Nov 15, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why did it catch on fire?
The round plastic cover at the top ceiling of the microwave caught on fire while popping microwave popcorn. Need any ideas about what caused this. Maybe the sturrer under the Magnetron stopped turning???? Need DIY repair advice.
Level 3:
  • Master 19,187 Answers
  • Posted on Nov 16, 2015
Master
Level 3:
Answers
19187
Questions
0
Helped
4339622
Points
82259
Any flaws in the painted surface on the inside of the unit will cause a spark and that generates heat. Examine the surfacecor any exposed metal. You have to use special paint to resurface the inside.
Testimonial: "Thanks for the comments, Brad. No missing paint. I believe the problem is defective plastic used for the stirrer cover at the top (ceiling) of the microwave. I took the plastic cover out this morning, trimmed the plastic that was stopping the stirrer from moving, and reassembled the thing. I believe the plastic deformed or bubbled up enough to stop the stirrer from turning, which allowed the plastic to overheat and catch on fire. I plan to order a new plastic cover unit, and continue to use the thing. Comments posted on the internet about GE microwaves would make a person swear off of anything made by GE!"
2answers
Kitchen aid microwave Kcms185j is arcing on the inside ceiling when popping popcorn, but normal when frying bacon?
It may be the oil in the popcorn---do you own one of the covers that go inside to cover so food does not splatter?
2helpful
Have a kitchenaid microwave KHMS2040WSS brand new. Is there a way to set the popcorn sensor for a smaller bag? Right now it is set for 3.5oz and burns all the popcorn.
I have never seen a microwave that doesn't burn popcorn if you use the "popcorn" button. Why the manufacturers keep putting them on I'll never understand. There's nothing you can do change the presets on an oven since they are built into the controller. Instead of relying on the oven, you should follw the directions on the bag. These tell you to use high power, stay by the oven and stop the cooking when the time between pops drops to 1 or 2 seconds. Stored heat will continue to pop kernels for a bit, and you won't cremate your popcorn. You'll also avoid the possibility of the bag catching fire and damaging the oven, which I have seen several times. Finally, don't expect 100% of the kernels to pop. There wil always be a few duds, and extending the cooking time just results in burned popcorn.
1helpful
A plastic container with hidden piece of metal caught fire in my Sharp r1490 and burned with a big flame. Several small holes were burned in the ceiling panel. Are we in danger of radiation exposure/ is...
The microwave oven is not safe to use, the fire has compromised the interior of the oven, if you run the microwave it will start to arc and eventually short out the magnetron, because the white enamel paint has been burned away. If you have holes in the ceiling there is danger of radiation leakage, for safety reasons the oven should be replaced.
Food in micro caught fire
It may have dried out from over cooking.
This is common in potatoes, popcorn, and other low-moisture foods.
The manual will tell you about that, and it will also tell you not to leave a microwave unattended while it's running.
I tried poping some popcorn in a brown paper bag and it caught on fire. I tried to the microwave again after i put the fire out and cleaned the mess up but nothing is working at all. No breakers were...
all microwaves have flame sensors that will cut the power in case of fire, this sensor will most likely have to be replaced. this will require you to drop the m/w and remove the case.
Roper microwave caught a paper towel on fire.
Why is this even a question?
Of course a paper towel can get hot enough to catch fire in a microwave. In addition, anything not specifically identified as microwave safe can melt, deform, crack, chip, spark, catch fire, explode, etc...
This is not a microwave problem.
2answers
Small 10 sec fire in microwave
it may be ok , but it should be checked for internal damage
Microwave (inside on right hand side wall) has a plastic cover. Behind this cover while popping popcorn there was bright yellow/red flashing/light, it started to melted the plastic cover within seconds....
You don't say which make/model microwave you have, but on every model I have ever seen the thing that sits behind the plastic cover is the magnetron - the bit that actually generates the microwaves.
Unless the microwave was a fairly top-end model, you might well be cheaper to just buy a new one.
Hope this helps,
Matt
Fire inWestinghouse microwave oven
I have contacted the manufacturer, Salton, Inc to complete the warranty. Thank you for the quick response.
Fire from top of Microwave
It's not a dangerous or diffcult job for a do-it-yourselfer.
That would be the waveguide cover (also called the stirrer fan cover), and it would need to be replaced to prevent future damage to the magnetron.
Check your model number sticker to get the full model number with suffix and the manufacturer number (PACO1860AB0 for example).
Then you can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Good luck and good cooking!
We appreciate your thoughtful rating of our answer.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
