Rangemaster 110 (Gas) Kitchen Range Logo
A
Anonymous Posted on Nov 15, 2015
One oven lights but will not increase temp to the required setting
When I light my oven, it stays on full all the time. Is it the thermostate
I'd recommend buying an oven temp dial to stick in your oven to verify the actual temp. Then you can turn on the oven using a lower setting and write down the temp for the setting. Then as you slowly adjust the setting higher and higher, note each temp. If it doesn't show a consistent increase of temp for each setting, you may need it calibrated or replaced. Good luck!
Sep 18, 2014 • Ovens
1helpful
How do I set the oven on100.
I'm guessing that you want your oven at 100 degrees for drying some food/herbs, or culturing homemade yoghurt. I do all of those, so know the temp range required; 95-110. Most ovens can't be set as low as 100, but the cool thing about a gas range is that the pilot light keeps the interior temperature close to that, and if you keep the oven interior light on, that helps. Get an oven thermometer, costs under $10, test oven temp. If your oven doesn't do it you can get a pizza stone or even a few bricks, preheat the oven to warm the stone/bricks on the bottom rack, turn oven off. Then put in your product of choice on top rack. Leave yoghurt in for 8 hours, leafy herbs (sage, thyme, oregano, etc) for 12 or more hours. If doing yoghurt, don't open door, consistent temp is important. If doing herbs, crack the oven door open slightly with a wooden spoon to allow moisture to escape, critical to drying. I hope this helps.
I have a Maytag model MER5775QAW free standing range. When you press "bake" and then set the temp. and press "bake" again the numbers instantly climb to the set temp and the buzzer beeps showing oven at...
Unplug the range open the control panel to access the electronic oven control. Unplug the wires and wait 5 minutes. Replace all wires on the control and turn the power back on.
If this does not reset your oven control it must be replaced.
Your ERC(clock) is bad and must be replaced.
1helpful
I have a Competence 52081 double oven. Ity has
Thermostat may need adjusting OR air may be entering the oven causing the problem
Sep 01, 2009 • Ovens
2answers
4helpful
GE JKP26GOP1BG Electric Oven won't maintain temperature
You will need to replace the temp probe Call704-891-6557 we'll tell you how to do it safely.
Mar 14, 2009 • Ovens
Wirlpool gs475lems Oven will fail to light and keep temp.
I HAVE A 2 MONTH OLD GAS RANGE AND IT APPEARS ED-F3 AND THE OVEN DOOR IS LOCKED HOW DO I GET IT TO UNLOCK
1helpful
Adjust temp level of the oven .. model 34ja-5tkxw
Press the bake key.
Adjust temperature to 550 degress.
Press the bake key again and hold it for 3 seconds.
The temperature +/- should appear.
You can then adjust temp +/- 35 degrees.
2answers
Oven temp indication
it could be your oven control unit
Top Rangemaster Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
