Used this program with Windows XP for many years & would like to use on my Samsung purchased 2014
SOURCE: My Samsung Tocco wont connect to my laptop with the software on
I think u would not had installed the drivers software properly. Uninstall the drivers for ur phone in ur laptop . then without connecting the phone to the laptop install the drivers . now restart and connect the phone to ur laptop . go to add hardware option and add the phone. now it'll ask for the location of software. select the option as cd. it'll ask for the port no. and all other details.. give them correctly ... select ur phone from the list and install it. now ur phone is ready to work with ur lap top
SOURCE: samsung yp s3 doesnt work on xp
I have Windows XP and Media Player 10.
I had same problem with Samsung media studio not recognizing MP3 player. Here is how I fixed it. With the MP3 plugged in, I had to go into System/ Hardware/Device Manager and find the S3 driver under "Windows portable Media" and uninstall it. Then unplug and replug the S3 into the usb so that driver gets reinstalled.
Then I decided windows media player and samsung media studio are unnecessary for transferring music files to MP3 player.
Instead I go into Portable Media Devices from the control panel and just treat the MP3 player like a usb device. I copy folders of music and songs into the Music folder on the MP3. For me this is way easier than the Samsung music studio or Windows Media player.
SOURCE: samsung laptop r 517 display driver for windows xp
Hello saisantoshil,
Please check this out,
http://www.megaupload.com/?d=HAHC9NBB
Hope this helps.
Art Pena
Tech Support
SOURCE: new samsung r519. integrated webcam works fine
est your webcam here to make sure it broadcasts ok - Hit 'Allow' in the top window and check your cam in the left hand panel.
http://www.testmycam.com/
Having proved your cam is working ,you can configure it to WLM (MSN)
CONFIGURE SOFTWARE to MSN
Its good practice to disconnect and re-connect your webcam before you start - if you have been using it elsewhere the MSN software may have difficulty in locating it, even if you exited the previous program correctly.
The reason being, the webcam software can remain hooked-up to a program and needs to be rebooted.
Mine, I just unplug it from the USB and plug it back in to reboot the software.
If yours is integral with the computer you will have to re-start the computer, use a keyboard shortcut or disable / enable the webcam from the Device Manager.
Open MSN
Click 'Open Menu'
From 'Tools; navigate to, and click, 'Audio and Video setup'
Set your speakers
Click 'Test' - if OK, move on.
Set your mic as default
Use the slider to set volume and test.
Click 'Next'
This takes you to the video setup
Your webcam should be broadcasting - if not - make sure the webcam is set as default - restart MSN
Use 'Webcam Settings'to fine tune the picture.
Click 'Finish'
SOURCE: I want to install Windows 7 on my laptop, it
If you are updating from Winos XP orsome higher version to Windows 7, an automatic update is run which backup allthe data, installed files and saved application settings.If you freshly install Windows 7 inyour PC, it will remove all the installed applications and saved settings.
