The 2nd Tray Lift motor. Remove draw #2 and check to make sure no paper behind the draw. Secondly REMOVE THE ETRA PAPER IN THE DRAW THE EXTRA SPACE IS NOT FOR SPARE PAPER, it for if you are going to put 11x17 paper in the draw. If these don't work you mite have a burned out 2 tray lift motor. When you close the draw that metal plate at the bottom of the draws goes up
2nd Drawer Lift-Up Motor Failure - The Lift-Up Sensor is not unblocked even after the set period of time has elapsed after the paper liftup operation for the drawer has begun.
Reset your Toners and Imaging units for Bizhub and CF series. http://www.chipreset.eu
System error code 6010 means "The directory has been disabled for
encryption." This error code may also display as
"ERROR_DIR_EFS_DISALLOWED" or as the value 0x177A. But without knowing the make.model of your printer hard to say more
The error code you are getting is a paper tray lift problem. Open all the paper trays and make sure that you have the correct size paper in each paper tray. Also, make sure the paper guides are tight againest the paper in the trays. Turn the copier OFF then back ON... Wait for the copier to come to ready and one tray at a time reinstall each tray at a time.... The one that cause's the error code to show up is the paper tray with the problem. Once you know what tray is the problem, remove the tray and look inside the copier for a wade of paper jammed behind the tray... If not you may have a bigger problem, then we can help with... Good Luck....
