First try this... put some 30 weight oil in the plug hole aso much as you can until it reaches top of plug hole. Let it sit there a few days allowing the oil to creep between the walls and piston. .. then try turning the flywheel with a socket and ratchet, a little forward, a little the opposite...
Now, if that doesn't work, it depends on your unit... if we are talking about a $400 top model back packer, then it would be worth getting it repaired... you would be paying between 150 and 200... if the unit costarts 300 or less than buy a new one... period
