Televison & Video Logo
j
jeanie dominek Posted on Nov 12, 2015
Why won't green timer light quit blinking? - WD Mitsubishi Televison & Video
Ron Hoffman
Level 1:
New Friend:
  • Contributor 40 Answers
  • Posted on Jan 05, 2016
Ron Hoffman
Contributor
Level 1:
New Friend:
Answers
40
Questions
0
Helped
16052
Points
48
Read Owner's Manual. Usually blinks when shutting down and waiting for fans to cool lamp below set temperature, then turns OFF. Takes several minutes. Regards.
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Aug 23, 2008
SOURCE: green timer light blinking constantly, no picture
You need the V21/V19 DM repair kit thats available at the following link, it contains the parts and step by step instruction CD so you can do the repair yourself. Its listed under their repair Kit category.
http://servicemanuals.vstore.ca/
Anonymous
  • Posted on Nov 29, 2008
SOURCE: Mitsubishi dlp tv green timer light blinking
timer light keeps blinking tv does not turn on
Anonymous
  • Posted on May 30, 2009
SOURCE: WD 62725 Timer geen light keeps blinking
Here is how you fix the problem. Turn off the power to your TV for 10 seconds, then turn on. Next, take a paperclip and push in the reset button for 10 seconds, then release and wait until the light stops blinking - may take up to 5 minutes - be patient. Then turn on your TV as normal and your problem will be fixed.
Anonymous
  • 60 Answers
  • Posted on Sep 11, 2009
SOURCE: Green blinking light under timer
I can almost guarantee that the circuit board(s) have bad capacitors on them. I repaired one last week that had 20 bad capacitors on 4 boards.
Fixed one the week before with 15 bad caps on two boards.
A repair shop may be able to replace the boards, but it may be expensive.
- I hope my diagnosis is wrong-
Anonymous
  • 65 Answers
  • Posted on Mar 22, 2010
SOURCE: green blinking timer light, TV won't turn on
Common to mitsubishi dlp tv's,you have a bad signal ***'y (power supply,formater board) lots of bad electrolytic capacitors,
1helpful
2answers
Green timer light won't stop flashing on mitsubishi ws 73711.
the green light blinking is normal if set has been unplugged--when set is plugged back it should blink for about 70 seconds and then go out--then you can try to turn it on---it is the DM unit inside the set booting up.
If the light just blinks and never stops you have likely bad caps in the DM unit---there are kits available for that.
The other possible reason is that so called reset switch may be bad--fairly easy way to find that out and it is more common than you would think, let me know if you have questions.
SD TECH
Green light on mittsubishi tv 65inch won't quit
It is the set's brain trying to boot up. (not unlike a computer) These sets if unplugged and power applied should blink 70 seconds and then go out and then can be turned on.
The model number will determine my answer/suggestions=
Models beginning with WD are nasty if this problem.
Models beginning with WS are not quite so nasty to deal with.
A full model number will tell which you have.
Replaced lamp but lamp light still blinks orange
I have a wd-57731 The lamp light blinked orange. i replaced the lamp turned the tv on and the timer blinks green for one minute and then the lamp light blinks orange again. It won't turn on. Can you suggest anything?
Mitsubishi tv ws-55859 after power failure green timer light won't quit blinking
there is problem withe your power board.check fuse,cap,if faulty replace with good one.
Timer light keeps blinking
you probably had a power bump, unplug tv for 1 hour turn back on and hit the reset button, if the green light quits blinking your good to go. If not you might have capacitors gone bad not cool.
Blinking light no power
Same here Once I plug the tv WS-55513 to 120 volts the green blinking timer blinks endlessly
1helpful
2answers
Blinking timer light on mitsuWS-55815
My mitsubishi little green timer light will not quite flashing and the tv will not come on.
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
