Uniden DECT1560-3 DECT 6.0 Expandable 3-Handset Cordless Phone System with Caller ID, DECT-1560-3,DECT 1560-3 Logo
Jackie Hadley Posted on Nov 11, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Two of my handsets do and have registered with the base, but the third one will not. I have tried both ways the manual suggests and the charge is 100% but not registering
richie46
Level 3:
Top Expert:
  • Uniden Master 12,962 Answers
  • Posted on Nov 11, 2015
richie46
Uniden Master
Level 3:
Top Expert:
Answers
12962
Questions
Helped
2943250
Points
58151
Unit is defective - try to exchange if new.
How to register a new handset?
Unfortunately, the EXI5560 is not an expandable cordless telephone system. The base can only use the handset to which it was originally linked at the factory.
Similarly, the DXA15588 handsets need to be paired to that base, not just to any Uniden cordless phone base. The first handset gets registered while it is charging in the main base. Charge the second handset fully in the charging base. Make sure not to use the phone for any incoming calls during the registration process. Take the first handset off the main base. You do not have to put this handset on the other charger and put second handset on the main base. Wait for the Charge/In Use LED to begin to flash. Wait at least another 5 seconds before removing the second handset from the main base. That's when you should be able to use the find HS button on the DXA15588-2 main base to get both handsets to beep.
I hope this helps. You can find the manuals for these phones at the following sites: https://www.uniden.info/download/ompdf/EXI5560om.pdf and https://www.uniden.info/download/ompdf/DXAI5588-2om.pdf .
D1780 with blank screen
Suggest you reset handset and register again with base.
Instructions from manual...
Resetting Handsets If you have trouble with a handset or if you want to replace one, clear the registration information from the base and the handset: 1. Press & hold END and # at the same time until you see the System Reset menu. 2.If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable. 3. To confirm, select Yes. The handset displays Handset not registered. Registering Handsets If you see a "not registered" message on a handset, you must register it to a base before using it. 1. Place the handset in the base; the display should say Handset Registering. 2.Wait until the display says Registration Complete (about 30 seconds), then pick up the handset and press TALK/FLASH. 3.If you don't hear a dial tone or the display says Registration Failed, charge the battery completely, then try again.
How to register 2 Bell Cordless handsets on 2 bases?
Multiple handsets registered to one base works well.
The extra base can be used as a remote charging
dock without registering a handset.
Trying to register a handset to two bases is neither
possible nor useful.
OTOH, the specific model number was
not given. While I have never heard of
registering a handset to more than one base,
nor made it happen by accident, maybe we
all do "...learn something new everyday...".
What is the specific model number, and the
date of manufacture ? Thanks! a r t
Hi, I have a DECT2085-3 base with 3 handsets. I would like to add another handset. I bought two used handsets and would like to register them to my original base. I am having trouble with the selecti
In the instructions you need to find how you Sync the base and add that number phone to the base. All have different ways so try the company website on google.
I attempted to register several new TCX 905s to my TRU 8866 base without success. I followed instructions from the owner's manual, from Uniden customer support, and from suggestions from this web site. ...
October 10th, 2013 at 9:19 amPROBLEM:
After de-registering handset, handset displays [REGISTRATION FAILED; UNAVAILABLE] when trying to register handset.
This worked for my UNIDEN TRU-9480-2
SOLUTION:
1) Remove handset from base
2) Remove power cord from back of base
3) Press and hold the [find hs] button on base as you plug the power supply back in; the charge light should then be blinking.
4) Return handset to base and it should register
GOOD LUCK!! HOPE THIS HELPS!!
2helpful
HOW DO U CONNECT THE HANDSET TO THE BASE.ALREADY TRIED THE REGISTER BUTTON,DID NOT WORK.IT CAME WITH NO DIRECTIONS,WE BOUGHT AT A FLE MARKET FOR 5 DOLLARS.
Are you sure of the model number? The D1680 should register the handset when you put it on the base for 30 seconds. (You should see Handset Registering followed by Registration Complete.) Then press Talk/Flash to check for dial tone. On this model if the registration fails, charge the battery (or replace the battery and then charge that). Then repeat the registration.
The manual for the Uniden D1680 is available here: http://news.uniden.com/pdf/D1680om.pdf .
For other Uniden phones, like the DEC1060, you need to navigate through the handset menus to find the Handset Registration command. Then press and hold the Register Handset (Find Handset) key on the base for 3+ secondsThen the base and handset will synch. (Low batteries could interfere with the process.)
For the D3288, you access the base menu for Register Accy and then press and hold # on the handset for 30+ seconds. (You will see Registering followed by Registration Complete.)
Additional Uniden cordless phone manuals are available here: http://www.uniden.com/scat/cordlessphones_mnl .
I hope this helps.
(with a flea market phone, my first suggestion is to try a new battery for the handset. They only have a given number of recharge cycles and you do not know the history. However, sometimes the chargers do fail and a new battery will not work. In that case, the phone should be replaced. It isn't worth the cost of out-of-warranty repairs.)
1helpful
2answers
I am trying to replace a handeset on my E5640 answering system. I have followed the procedures to deregister the existing handsets but it will not accept the base code for the last one. The handset I am...
  • Your telephone can accommodate up to four cordless handsets. You can add new handsets (Model E560-2, sold separately) at any time, but each must be registered with the base before use.
  • The handset provided with your telephone is automatically registered as Handset 1.
  • Additional handsets will be assigned numbers in the order they are registered (2, 3 or 4). You can register a maximum of four handsets.
To de-register all handsets
• Unplug the power supply from the base unit.
• Remove all handsets from the charge cradles and base.
• Plug in the power supply while pressing and holding the HANDSET LOCATOR button.
• Continue pressing HANDSET LOCATOR until the IN USE and CHARGING indicators are lit (this could take up to 10 seconds).
• Release the HANDSET LOCATOR button.
• All handsets will display: ENTER BASE ID: XXXXXXXXXX
Once the base indicators turn off (up to 30 seconds), the handsets have been de-registered from the base, and can now be re-registered.
To re-register a handset:
• Make sure your handset batteries are properly installed and charged.
• Your handset will display "ENTER BASE ID".
• Enter the 15-digit Base ID number from the bottom of the base unit.
• Press SELECT to accept the new code and complete re-registration.
To re-register a handset to a new base unit:
• Unplug the old base unit. Your handset will display "SEARCHING...".
• Install the new base unit by plugging it into an electrical outlet and phone jack.
• Press and hold the SELECT key until the handset displays "ENTER BASE ID".
• Enter the new 15-digit Base ID number from the bottom of the new base unit.
• Press SELECT to accept the new code and complete re-registration. The handset is now registered to the new base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Uniden Have problem
Dear....Fixya Team,
I'm Soontaree. Thank you for your reply email. I would like to let you know i'm already solved this problem. I just have a look from the Uniden Manual so i just follow them detail like as below,
Thank you for your help i will contact to you later if i have anything problem.
Have a great day.
Soontaree
Registering DSS7905 Accessory Handsets
Your phone supports a total of ten (10) cordless handsets. Handset(s) supplied in the box with the phone base are
pre-registered at the factory. If you purchase an accessory handset, you need to register the handset before use.
Only one handset can be registered at a time. When charged, pre-registered handsets display a handset ID number.
Handsets that have not been registered display.
Before registering the DSS7905 accessory handset, the battery pack MUST be charged for 15-20 hours.
To register the DSS7905 handset:
Place the handset in the telephone base charging cradle to begin registration.
During the registration process, HANDSET REGISTERING will appear in the LCD. When REGISTRATION
COMPLETE. is displayed; the handset has been registered to the base. If REGISTRATION FAILED. appears,
please try these steps again. When you register an accessory handset to the base, the handset ID will be
assigned.
Note:
If an accessory handset has ever been registered to a base, you must reset the handset before you can
register it to a new base. See Resetting the Handsets on page 24.
1helpful
3answers
Doesn't anyone have an answer or some help? Please!!!!
Uniden TRU8885-2 Cordless Phone > User Guide E X P A N D I N G Y O U R P H O N E w w w . u n i d e n . c o m Register the Handset to the Base If you purchase an extra handset, you need to register the handset to the base before use. Only one handset can be registered at a time. The handset ID for the supplied handset(s) was assigned at the factory, which has #1 or #2 in the display (#2 for models that have two handsets in packaging). When you register additional handset to the base, the handset ID will be assigned. 1) Before registering the extra handset, the battery pack must be charged for 15-20 hours. 2) Place the extra handset in the main base unit to begin registration. 3) While the handset is registering, Handset Registering will appear in the LCD. When Registration Complete is displayed, the handset has been registered to the base. If Registration Failed appears, please try these steps again. Extra Handset Extra Handset Charger Charger Main Base Extra Handset + Main Base Charge the handset for 15-20 hours. Place the extra handset in the main base to register. 1 2 3 4 ?An extra handset can be registered when the main base is in standby mode. ?Standby Mode - The handset is not in use and talk/flash has not been pressed.
Top Uniden Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you an Uniden Electronics - Other Expert? Answer questions, earn points and help others
