Samsung LN-T5271F 52 in. LCD Television Logo
D
Dante Simmons Posted on Nov 10, 2015
Why does it have a double picture when turned on?
I am just wondering which board I need to replace or is it unfixable or what I can do. This problem happens on any picture and only started to happen recently on and off. Now it is on permanently. I wonder if something is actually wrong or maybe something is lose and needs a refitting. Again the picture, or on TV graphic (like HDMI 2 for example) jitters and doubles itself up and down on the screen. This happens with anything the screen projects. It is like a double image but scattered only vertically. Thank you.
5 Related Answers
smbaby
  • Posted on Sep 22, 2009
SOURCE: Samsung LN-R408D - No Picture
My Mom's LNR408D also had sound but no picture. I was able to fix it by soldering in a jumper wire across a blown (1.5A ???) SMD picofuse on the "T-Con" board.
Consider attempting this ONLY if you: 0) Know enough to avoid the potentially fatal High Voltage parts of the power supply board!!!
1) Are a fearless hackazoid 2) know what you're doing with a soldering iron and teensie SMD parts 3) are gonna throw the busted thing out anyway so you have nothing to lose and won't be sad if you screw something up.
4) Know enough to avoid the potentially FATAL High Voltage parts of the power supply board!!!!!
This board is at the top center under a close fitting RF shield. The suspect part was labeled "CP" on the board and marked with "P" on the part. It is visible above the right-center of the connector from the main board. An ohmmeter showed it as open, so I bypassed it with a jumper wire from connector VIN to the hot side of C13. One image shows the suspect part and the jumper in place.
The other shows the TCON board placement top-center (under its RF shield). With care, it seems possible to test the fuse and put the jumper in place without removing the shield. (Obviously don't touch anything else with the VOM leads!)
Thanks to ZORBUS and Steve's TV and Electronics for the idea.
http://www.avforums.com/forums/lcd-televisions/892447-no-picture-but-got-sound-my-samsung-lcd.html
http://www.gesda.com/transformer/Fall08_files/Page336.htm
Steve C
Chi Chu
  • 8457 Answers
  • Posted on Jul 22, 2010
SOURCE: We have Samsung LCD model LN26A450C1D, which is
The tv Tuner board is dead,that the board,where the brocasting incomming signal cable connected into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.
Testimonial: "Thanks for quick response! I will try. "
Anonymous
  • Posted on Sep 10, 2010
SOURCE: Picture on Samsung LCD LNT5271F is blurred
Had this exact problem diagnosed by a local repair shop as a bad LCD panel. According to the technician there's a loose ribbon cable on the panel and it would cost as much to replace/repair as a new TV.
Anonymous
  • 608 Answers
  • Posted on Dec 10, 2010
SOURCE: Samsung 46" LCD LN46B650 started showing vertical
had a very similar situation with my Phillips 42 in. LCD TV.
Here was my Problem. The Power Supply Board. I opened it up( Warranty was Expired) and found several faulty capacitors on the PSB. Its pretty common. Major Electronic companies were sold faulty capacitors that fail in 2-5 years instead of 10-20 due to a lack of preservatives. It wouldn't surprise me if you have the same problem. TV will work fine for a few years and then just fail completely or slowly deteriorate.
Here are the solutions
1. Have it Repaired
2. Check for faulty caps and if you find some(budged or leaking) you know you have located a problem
Remove the board and replace the whole thing.
3. If you have some soldering skills you can replace the faulty caps.
Caps are very inexpensive, under a dollar in most cases. I replaced 4 for about $5.00
Hope this Helps.
Good Luck
Anonymous
  • 4889 Answers
  • Posted on Apr 12, 2011
SOURCE: My Samsung LCD TV has
Can you please get me a picture so that I can see for myself. It sounds like an issue with A/V processing circuits but I would like to be sure.
My Phillips 47 LCD TV is loosing picture but is keeping sound.
Main board feeds the t con board. However try the flash light test on set because it might just be the inverter board that powers the backlighting.
1helpful
Television keeps losing its picture quality and turns itself off.
your T-Con board is failing you need a tech to replace it
Has double picture.
Double picture means TV got problem in convergence out section as it is necessary part of rear projection TV.
Usually convergence out chip got bad in rear projection TV due to heat or dry solder joints in circuit board and need to be replaced. You can replace it if you have sufficient knowledge and experience of electronics stuff repair and can solder parts in circuit board with proper tools.
Rear projection tv screen warped
HI, this is typical convergence chip failure. you will need to replace the convergence board in this set asap. this will fix this issue you are experiencing.
RCA PICTURE
Its a convergence problem either the convergence board or the convergence power supply board needs replacement. The following link will help you determine which board you need, just leave them a email with your model number and symptoms.
http://servicemanuals.vstore.ca/
Lg 42pc1d plasma tv red sparkles
I had the same problem, LG came out and it turned out to be the board that filters out the interference around the screen. I pretty sure that was it, took them 10 mins to fix by replacing a few of the boards inside the screen. Sorry I can't be more specific but its not an unfixable problem, so nothing to worry about.
2helpful
2answers
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
