Sounds like you need to sign in to your Google account to verify your identity. If you've forgotten your credentials and back up credentials and have no way of getting back into the account, you may be out of luck.
Google Play services is used to update Google apps and apps from Google Play. This component provides core functionality like authentication to your Google services, synchronized contacts, access to all the latest user privacy settings, and higher quality, lower-powered location based services
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - ‎9 authors
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
I assume you're using a secure Wifi connection with a password and it seems like that authentication is not working. You could try using an open wifi access point to eliminate the possibility of this authentication issue.
Depending on the firmware revision you may be able to reset the password through Google Authentication so first your tablet must: 1. Have been registered with a Google Account 2. Be connected to the internet 3. Have the latest version of Cruz Reader Firmware
If the above is try, try the following to reset the pattern: 1. Try to unlock the pattern 3 to 5 times until you see "Forgot Pattern" pop-up 2. Click on the "Forgot Pattern link 3. Follow the steps to reset the pattern
