SOURCE: HAVE BUNN NHB COFFEE NOT HOT ENOUGH ON BREWING
I work for BUNN. Please call our customer service team at 800-352-2866 so they can talk thru what's going on and solve this for you.
SOURCE: My Bunn coffeemaker NHB is leaking from the bottom
If you will call Customer Service with your Model and Date Code located on the bottom of the brewer, we can assist you with this problem.
SOURCE: Hi: My Bunn coffee maker started
Tom, your machine is out of warranty but we can offer a replacement brewer for $68.43. In order to do this, please send in a check or money order with your brewer to the following address:
Bunn Corp
900 E Townline Rd
Creston, IA 50801
Please include a note with the machine with your. name, address, and phone number.
SOURCE: Bunn NHB model leaks water
Please call customer service at 800-352-2866 with the date code from the bottom of your brewer. We will be happy to assist you with this issue.
SOURCE: Bunn Coffee Maker Leaks out the bottom
I have an older BUNN B10 pour-o-matic that I thought was leaking from the bottom. Upon close inspection, I found that it was leaking from the worn out washers located on the top of the tank, allowing water to run down the sides of the stainless steel tank. There's a great fix offered on Fixya.com that suggests going to a hardware store and buying a Gardner Bender GHG-1575 rubber grommet with a 3/4" hole and install it into the large hole in the basin. Then place a metal washer on top of the grommet and snug it up with the threaded fitting. Many folks say it's a great fix. I went a different route. I called BUNN customer service and spoke to a very nice woman who understood my needs and sent out a free repair kit that contained a new fitting, washer, and seal. I received it in a few days and it's working great. Beats going out and buying parts for a work around repair. BTW, the repair kit is called "Universal Retail Seal Replacement Kit #37091.0000"
