On sewing machines, when you lower the feed dogs the machine lowers them immediately. However, when you RAISE them, you must turn the hand wheel TOWARDS you several times before you hear them click into place. ALWAYS turn the wheel towards you for anything.
Perhaps this web page will help:
sewing patternreview com
A lot of machine feed dogs will not raise until the handwheel is cycled.
SOURCE: babylock ellure feed dog will not raise
go see your local parts man. he will know what you need and he will have it there or he will need to order it.
SOURCE: Feed dogs do not come back up after lowering
Are you talking about the feed dogs or the presser foot. Either way, if you moved a lever to lower them, there is probably a screw that either fell out or has become loose that holds the linkage to the lever.
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
SOURCE: Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Thank you. It worked !
