Admiral AW22 Top Load Washer Logo
L
Laurie Ervin Posted on Nov 09, 2015
Where is the hose filter located on an admiral mega 22 plus top loader
The washer won't drain from the rinse cycle and just hums. Trying to find out where the hose filter screen is located to see if it is plugged.
2 Related Answers
Yozzer6821
Mark Hughes
  • 116 Answers
  • Posted on Jun 29, 2009
SOURCE: the lid on my top loading admiral mega 22 plus washing machion is
These are plastic and will need to be replaced with new.
Once you have sourced new hinges then the machine top needs to be opened,
Electrically Isolate the machine, then at the joint between the machine front panel and top insert a flat blade 4" from each side to release the lid catches, tilt back the top to access the screws on the hinges and replace with new.
Anonymous
  • Posted on Aug 04, 2010
SOURCE: Admiral Mega 22 Plus-Heavy Duty-2 speed Washing Machine
After spinning it does not release the water
2answers
I have Admiral Mega-22 heavy duty 2 speed washer that won't fill up with water.
Question edited for *Admiral.
Question moved from Speed to Admiral Washing Machine Category.
First check the strainers on the hose inlets to the machine. However it is likely to be the Water Inlet Solenoid.
Replacement videos
https://www.google.com/search?q=Admiral+Mega-22+water+inlet+solenoid+valve
3helpful
2answers
Ltf2940fe
Hi Kimberly, this is AP. Thank you for your post.
I understand you are having trouble with your Frigidaire front load washer, model LTF2940FE, not draining or spinning. There are a few possibilities that could be causing this to happen.
Overuse of detergent can result in oversudsing then restricting the tub from turning properly and not spinning out. You can attempt running a cold water rinse cycle to get rid of suds if this is case.
Another possibility could be that the drain hose is too long or restricted. If the drain pump makes a humming noise there could be a restriction in the drain line. Confirm that your standpipe (located in the rear of the washer) height is not higher than 96" and not below 24". Lastly, if the drain pump does not make a humming noise once the washer is in the spin cycle a defective timer or drain pump could be the cause of your washer not draining or spinning
If you can determine that oversudsing, a too long or clogged drain hose is not the root of the problem I would recommend contacting an authorized technician. Contacting an authorized technician can ensure no troubleshooting step has been missed. Parts can be costly and if the problem is precisely diagnosed, it can save you a lot of time and funds. I have provided a link below that will assist you in locating and authorized technician in your area if needed. I hope this information proves helpful for you.
http://www.frigidaire.com/Owner-Center/Locate-Service--Parts/
My HE2 front loader has a problem draining. It will be "locked" after washing. It is either full of water still, or needs to go through an extra "rinse and spin" cycle to drain the...
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely, if the issue returns then it is time for a new pump. Hope this helps... Please post back for any further assistance.
Daniel
1helpful
Quite old admiral mega 22 plus topload washer. the machine did not agitate after filling up. I tried various points on the 3 cycle types and it did not spin either. My son tried moving the agitator and...
Yes sounds like you have now disturbed the seal and will need a new one, remove the agitator and inner drum to get at the seals, to remove the agitator pull off the softner cap and remove bolt form down inside.
To remove the inner drum, the top part of the washer needs to be hinged back to gain access, to do this insert a flat balde 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the drums, on the outer dum there are clips all the way round to remove the top section of the outer drum release these. remove the bolts under agitator to remove the inner drum. you should have access to the seals but it has been a while.
Reason for not agitating in first place is probably the water level switch at the rear of the drum with a small 8mm hose connecting it to the drum.
1helpful
Sometimes does not spin enough to wring out water from clothes.
The spin cycle should be on a timer,and shouldn't be able to change how long it spins.The same timer that controls all the cycles of your washer.Your pump may be trying to go out,and isn't removing the water fast enough.This will keep water in the tub,and the normal spin cycle isn't long enough to let the pump get the job done.Another problem might be a clog in your drain hose.Another problem could be the drain hose is set to high above the pump,and the pump can't push it up that high (shouldn't be a problem if you are using the hose that came with the washer,and not extending it with another hose or something.)
Washer not cleaning clothes
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Try using powders for 'front loaders'
The lid on my top loading admiral mega 22 plus washing machion is
Admiral Washer not spinning
broken or slipping drive belt, ( motor) to spin pulley , losse pulley, defitive drive clutch, spin brake fails to release, or transmission is frozzen
Top Admiral Washing Machines Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
