Is it charging/turning on with the car charger that came in the box? If it is, then it is possible your cable is not inserted properly or it is defective. You can try another USB to Mini USB cable (should not be too costly) and see if it works.
To download the maps, first go the the Garmin website: https://connect.garmin.com/en-US/start/
and download the Garmin Express program, install it, plug in your device. It will be found by the program and the updates should be begin.
Hope this was helpful, don't forget to click the HELPFUL button below.
The problem you have stated can be due to several causes. Please eject your USB drive from your computer and insert it again. If windows does not detect it, then restart your computer and try again. If the problem is still there, please check the Device Manager if the USB port is properly working and if it is possible to use the troubleshoot. The best way to check whether your USB device is properly working or not, insert it to another computer other than your's. If the problem persists, check your USB device's warranty period and simply go for the replacement and contact your retailer or service provider.
You can go to Device Manger by following the steps below:
My Computer Icon>Right Click on the Icon>Properties>Device Manager
Is this the first time you connect your printer on that computer? This can be the USB port does not support a 2.0, or your data cable/printer cable is damage.
if you are having technical problem with your archos 605 just do this connect your USB with your computer and your archos device will pop up on the screen asking you if you want to charge your device or enaable usb that will automatically appear if your computer doesen't reconise the device then switch it off and on again if doesen't work then i suggest you look it up on the archos manual which is located on your device. if that doent work then i think you may need to update your computer it must have windows Core dual processor if that don't work and your archos device doesent appear then i think you may need to update your computer with a service pack 2 installation cd
