No matter what I try and drill it does not pierce anything. Needed a small hole in sheetrock the kitchen wall and zip, nadda, nothing, doesn't even scratch the surface? It is electric.
I tried changing bits, applying more pressure, what else can be the reason it won't drill a hole at all. Thanks
I suggest you pre-drill holes in the wood -- evenly spaced holes, all in a row, so that later on you can drill screws into the concrete anchors you will drill into the brick or the concrete between the bricks.
After pre-drilling holes in the wood, measure how far apart the holes are. Determine where on the brick wall you want to drill to insert the concrete anchors (which will accept the screws to hold the wood on the wall). Mark on the brick wall where the drilling for the anchors (to match up with the holes drilled in the wood) should be. Drill into the brick or cement between the bricks.
Then, assuming the hole measurements on the wood match up to the drilled holes in the wall, attach the wood to the wall with the proper anchor bolts/screws.
Well here is a tip that im shure you will enjoy!
How to patch a hole in your wall !
Don,t worry about cutting from stud to stud so you have something to screw too, just cut out a piece of sheetrock alittle larger then your hole ,
Then take your cut sheetrock piece and put it over the hole!
Then take a pencil and trace the cut sheetrock over the hole
Then cut out the hole to the size of the traced piece of sheetrock
OK here comes the fun part: Take 2 larger wooden paint mixing sticks (you can get them at any paint store , sherwin williams,ben moore, home,depot , sears, wallmart,lowes..you get the idea! and there always free so stock up for future holes,
Now take one stick and put it into the hole so that both top and bottom of the stick are equal lengths so that you can put 1 screw countersunk on both ends from the wall side ...what that screw is doing is making a secur backing for you to screw your cut piece of sheetrock to! ...but one is not enough so get that 2nd paint stick out and stick that also behind the wall and screw it from outside at top and bottom ...now your ready to screw that piece of sheetrock to the painsticks ..after thats done just tape and spackle ...once you try this you will always use this technique ,,GUARANTEED!..good luck and happy repairs, glenn
I like the plastic zip-it anchor because it is pretty strong for towel rack or shelf with a few books etc, It simply drills flush into the wall and then you can use a regular pan-head or drywall screw to connect shelf to zip it. Later the zip it can unscrew and hole is filled easily.
Wall dog is nice for 1 step into drywall. Lightweight shelf, with 2 small books and vase..
Toggle bolt for heavy shelves, But requires good sized 1/2" hole drilled first, and takes a few skill techniques.
Little holes... Spackle. Holes the size of a door knob, go to a "big box store" they have a repair kit, that makes things easy. But if it is a larger hole you will need to cut a matching piece of sheetrock to fit. Then tape and spackle and sand and repaint. If the hole is larger enough but is not big enough to involve one of the studs, then the "big box store" has some clips that will hold a piece of sheetrock suspended between the good and bad portions of the wall.
Mellisia, the problem very well may be, that the drain pan hole under the unit, on the outside may be clogged. When that happens, water backs up and leaks out the front of the unit.The drain hole should be near one of the corners of the drain pan. And with Fedders, it may be on the edge/lip of the drain pan. The clog, may appear to be part of the drain pan and that's why you haven't noticed it.
Inspect the drain pan closely. If you can't find it. You can create one, by CAREFULLY drilling a hole at one of the corners of the drain pan. It doesn't have to be a large hole 1/8" to 1/4" should do.Be sure the unit is OFF and unplugged from the wall, before attempting this. Also, once the drill bit penetrates the drain pan STOP. You don''t want the drill bit to pierce the coils on the back of the unit.
hope you dont plan on hanging anything heavy on this. get a drill bit and drill a hole smaller than the anchor you are using, tap the anchor into the sheetrock until its flush, drill the hole at least an 1/8 inch smaller than the anchor so it will be tight enough to keep the anchor from spinning when you insert the screw
There is no single answer that I can give you because it will vary due to material you are mounting to. If you are going to be mounting on ceramic tile or fiberglass shower wall I would recommend you use the plastic anchors that come with the bracket and mounting screws. Use drill size 3/16 drill holes and insert anchors. Mount bracket and screw in place. If you have hollow wall with nothing but sheetrock to hold the bracket I would get small butterfly anchors from hardware store and drill hole slightly larger than the wings on fastener when they are folded back along side the screws.If you have a wood backer board behind shower wall then drill holes with 1/8 inch bit and use screws long enough to reach through shower wall and sheet rock and mount bracket. Hope this helps you. Thanks P.S. If you have to drill thru ceramic tile you will need a carbide tipped bit.
Hello. The best thing for you to do is take your bracket to a hardware store and get the largest diameter screw you can that will fit easily into the holes. Regarding length, you should try to screw into the wooden studs behind the sheetrock or plaster wall so you will want 2 and 1/2 or 3 inch screws. Be sure to drill a pilot hole for each screw but only go in half as deep as the screw is long and use a bit that is only half as big around as the screw is.
If you cannot access a existing grommet, just drill a small hole through the firewall on the passenger side. Take a moment and look carefully so you will not pierce or damage other parts. Usually with most vehicles you can find a good spot to make a hole. You can purchase a grommet to fit the hole you are making, or just goo it with silicone so the power line will be knick free and secure. Pull back the needed carpet and mating. You may even find a wiring harness under there that connects through the firewall, if so, you may be able to squeeze through the side of it.
