Cell Phones Logo
P
Pamela Becker Posted on Nov 06, 2015
How do I get the light on the iphone off? - iPhone Apple Cell Phones
hostrapid
Level 1:
  • Contributor 3 Answers
  • Posted on Nov 06, 2015
hostrapid
Contributor
Level 1:
Answers
Questions
0
Helped
308
Points
If you are referring to the light at the side of the camera, this is the torch which you can turn off by sliding your finger up the centre off the screen from the bottom and you will see a menu like the one shown.
Click the left hand picture of the torch to turn it on and off.
Hope this helps...
2answers
How do I turn phone ringer strobe light on in iPhone 6Plus
  1. Launch the Settings app on your iPhone.
  2. Tap on General.
  3. Inside the General menu, tap on Accessibility.
  4. Scroll down a ways and under the Hearing section, turn the option for LED Flash for Alerts to On.
Why does the flash light on my iphone 4 stay on?
Virus or malware download avast from app store run full
2helpful
Connect to iPhone 4
Hold the "Answer/End" button on your Jabra Bluetooth headset down until the LED light on the headset turns solid blue. The location of the button may vary based on which headset you have, but its appearance will be the same; it is the button that has an image of a telephone on it.
Click on the "Settings" icon from the main screen of your iPhone 4 .
Click on "General" in your iPhone's "Settings" menu.
Click on "Bluetooth" to access your iPhone's Bluetooth menu and then click the option to turn on your iPhone's Bluetooth connection. Once your iPhone's Bluetooth is turned on, it will search for available Bluetooth devices.
Select your Jabra headset by clicking on the icon that appears on your iPhone's screen.
Enter the passkey for your Jabra Bluetooth headset. The default passkey on Jabra headsets is "0000."
Click on "OK" on your iPhone 4 to complete the connection to your Jabra headset.
Tips & Warnings
The LED light on your headset must be solid blue to pair to your iPhone. A flashing light indicates your headset is not yet in pairing mode and your iPhone will not be able to connect to the headset.
Having your iPhone 4 Bluetooth turned on will drain your phone battery faster than normal.
3helpful
3answers
My iphone screen light not working but everything else still working fine
phone 3gs has additional accessiblity functions like ‘voice over’
This function gives u addtional use of iphone with tapping by using two and three fingers
Tap three fingers three times on your iphone screen. It will deactivate the screen curtain and your screen will display as usual.
If not resolved try resetting your iphone by holding down home and sleep/wake button for 10 seconds..
if still not resolved restore your iphone using itunes…..before restoring ALWAYS make a backup. If these steps do not resolve the issue, there is a good chance that the backlight has go out. I hope this helps you! Good luck and please vote if this helps.
3helpful
3answers
IPhone display light problem: My iPhones display light is no longer working. It randomly works from time to time however if I hit the home button to display my keylock it does not light up thus making it...
Try to factory reset the iPhone with the latest version 3.0 on iTunes and see if that helps if not then its a hardware problem and not the software issue.
Iphone totally blackout
your phone battery is dead. please take it to service center. as we cant replace battery by ourselves.
Iphone and headset
Is this the first time you're pairing iPhone and jawbone or it's been working before?
If this is the first time,
1. Go to settings-general-bluetooth and turn on the bluetooth on your iPhone 2. Press and hold the button above the LED light until the LED light flashes Red and White 3. Go to your iPhone and click on Jawbone and it should connect.
If it's been working before:
1. Make sure Jawbone is fully charged. 2. Press and hold the button below the LED until white light blinks 3. Go to iPhone make sure bluetooth is on press Jawbone to connect
If this procedure fails try the to follow the First Time Pairing Instruction
Hope this works for you.
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
