Electronic control has detected a fault or error condition. Press CANCEL to clear the display & stop beeping. Try the selected feature again. If the E or F error code repeats, remove power from appliance, wait 5 minutes and then repower appliance. Try the selected feature again. If the fault recurs, record the fault or error code and call for service.
f1 is usually a control error fault usually means the control board has to be replaced in the unit this is what it says in the service manual for your error GE Gas or Built In Oven Fault Codes F0 or F1 - Failed transistor in control - If code cannot be cancelled, replace the Electronic Range Control (ERC) or touch pad how to distinguish between a fault with the touch pad and the control you would have to take and disconnect the power to the unit first and then unplug the touch pad from the control and then replug the unit in for 5 minutes if the error code is still there then you have a defective electronic control if it is not then you would have a defective touch pad it is very rare that you do get both that are defective all at once if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to continue to help others in similar situations in the future Thanks again I await if you have any further reply
Rick
Hi. This Usually means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
Frigidaire oven fault code F1 means the electronic clock control is bad and should be replaced. That is the electronic control board that shows your clock display and is also called clock or eoc, depending on your model.
