SOURCE: How to clear a Machine Error 76
Error 76 is fuser error, you need to change the fuser but first just in case try to reset settings to factory defaults.
SOURCE: fuser problem with Brother MFC 9420CN laser all in one
Unplug the printer and allow it to cool. Then gently wipe off the surface of the photo-sensitive drum with a cotton swab. If this doesn't work you may need to replace the drum.
SOURCE: Paper Jam Around Fuser Unit
Remove the fuser unit and unwrap the paper. The instruction book should tell you how.
SOURCE: Paper Jam
what you need to do is pull out the drum and remove the paper that you can see.
just pull out the drum unit harder.
SOURCE: DCP 7020 Brothers laser printer paper jam & back cover open fault
Try doing the following prior to messing around with the fuser itself:
http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002000/000024/faq002024_006.html?reg=us&c=us_ot&lang=en&prod=mfc7820n_all&Cat=4
13.20 PAPER JAM CHECK REAR DOOR
Media stopped in the paper path during power on
or when the top door was closed.
Action:
1.
Open top cover and remove toner cartridge. Remove all media in the
paper path, and then re-install toner then open and close the top cover.
2.
Open read door and pinch blue latches on fuser and pull it out.
Inspect the sensor flag for correct movement and any paper obstructions in the
fuser rollers. Re-install fuser and Confirm rear door closure.
3.
Remove tray 2 and confirm paper is not jammed in the pickup area.
Confirm paper size adjusters in the tray are correctly set for paper being
used. (Do not set back paper stop to ANY)
4.
Replace any defective sensors or flags
Hope this helps. Please keep us updated and
remember to rate this answer.
TF
Make sure that the printer is turned off.
Open the printer cover by pressing the latch on the left side of the printer and lifting the cover up all the way.
Warning: Opening the printer cover exposes the fuser, which is marked CAUTION Hot Surface Avoid Contact. Be careful not to touch the fuser. If the printer has been in use, the fuser may be very hot.
1. CAUTION Hot Surface Avoid Contact
Remove the developer cartridge.
Caution: When removing the developer cartridge, never touch the developing roller under the flap; otherwise, print quality may decline.
Remove the photoconductor unit.
Caution: Never touch the photoconductor unit's light-sensitive drum; otherwise, print quality may decline.
Remove the paper from the paper path.
Note: If paper is jammed at the fuser, grasp the bottom of the paper and pull it out.
Reinstall the photoconductor unit, and then the developer cartridge.
Close the printer cover.
Tap the edges of the stack of paper on a flat surface and carefully reload it into the MP tray. (Do not reload curled or wrinkled sheets.)
Printing automatically restarts from the page that jammed. If the Paper light stays on after removing all jammed paper, open and close the printer cover to clear the error.
