I also needed to remove the "hidden" flow restricters from my Price Pfister Parisa Kitchen Pull out faucet. The hot water side had never flowed the same as the cold side. Now both sides are flowing the same as should have been all along.
Price Pfister Marielle Kitchen Faucets Do come with a limited lifetime warranty from Price Pfister-to the original home owner. You can contact Price Pfister on line at www.pricepfister.com, call them toll free at 1-800-PFAUCET or Email. The faucets warranty can be downloaded at http://www.pricepfister.com/support/warranty.aspx.
Remove and clean the Price Pfister aerator. Turn the water on after you remove the aerator and check the flow-rate. Many new Lavatory and kitchen faucets are now equipped with Eco friendly water saver aerators. if the flow is normal without the aerator, the faucet is OK. if you want more water flow from your lavatory faucet, you will need to buy one of the old style high flow aerators from your hardware store. If you remove the aerator and still get low pressure from both hot and cold faucets, you may need to replace the faucet. Call the Price Pfister warranty phone number that came with your faucet.
Very nice kitchen faucet. I like Price Pfister's products. To repair it you will need a phillips screwdriver to remove the handles and crescent wrench to remove the cartridges. If it is dripping then one of the faucet cartridges need to be replaced. Its best to replace both cartridges as inevitably the other one will start to leak after you've replaced the troublesome one. Your local hardware store or plumbing supply store should have a replacement cartridge for this model. Remove one of the cartridges and take it with you to ensure you get the correct part. There is an exploded diagram of your faucet on the Price Pfister site at that shows the part number for the cartridge. Good luck and let me know how it turns out.http://www.pricepfister.com/www/ImageAssets/mirror/model/kitchen/savannah/savf8h6-85/ex-036-01.pdf
Three possible reasons for low pressure. 1. faucet cartridge has debris in valve body. 2. aerator has debris ,just unscrew and clean out. 3. Water valves under sink are not opened up. hope this helps
