One we thread the machine & get the bobbin pull in, I try to sew a sample stitch & the thread keeps coming out the needle
Make sure you pull at least 6 inches of thread tail through the needle eye before beginning to sew. It also helps to raise the needle to its highest point BEFORE threading the needle.
Try pulling the bobbin thread to the top of the fabric before beginning to sew. Here's how:
How and Why to Bring up the Bobbin Thread
HINT: To make needle threading easy, lick your finger and rub it on the back side of the needle eye. The moisture will help grab the thread end and pull it through the eye. Easy Peasy!
After threading the needle pull about 6" of thread out the back under the press foot
that way the thread is jammed under the foot and is held in place for the next thread
bobbin thread should also be out the back
when you have finished sewing then lift the foot and move the material sewed about 6"" away from the foot before cutting the threads
