For the Uniden DECT 6.0 6035 system...
Setting a Security Code or Personal Identi?cation Number (PIN)
To play your messages from a remote location, you will need to enter a two-digit security code or Personal Identi?cation Number (PIN). The default security code is 80. To change the PIN:
1) On the handset, press [Menu/Select]. Select the ANSW. SETUP menu, and then the SECURITY CODE submenu.
2) Use the number keypad ([0] through [9]) to enter a two-digit security code (00-99).
3) Press [Menu/Select]. You will hear a con?rmation tone.
Here is the manual:
Uniden 6035 1 Owner Manual
SOURCE: How do retrieve erased messages on the Uniden Dect
Sorry to tell you, but you cannot retreive a deleted message. These phones use a flash type memory and once data is erased, it is gone.
SOURCE: How do you change the number of rings before
Here is how to kill two birds with one stone.
http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%20DECT%206.0http://www.uniden.com/products/productlisting.cfm?cat=Cordless%20Phones%20DECT%206.0
That is the page for Uniden DECT phones. www.uniden.com.
There are 6 pages to flip through and all you need to do is look at the picture for you phone. Click on it and it takes you to the phones page. On the upper right sid there is a link to download the owners manual in pdf form. Unfortunetly I can't tell your model from the information so I can't tell you the page or how to do it. Hopefully the manual will get you sorted out.
SOURCE: UNIDEN DECT 6.0
DECT 6.0 is not a model number, it's the generic name for the cordless phone technology in use. So I can't give you a more specific link than this one, which takes you to Uniden's download page for manuals. Pick your model from the list, and the manual will explain the steps you'll need to follow. Your phone's model number is on a sticker normally found on the rear or bottom of the base unit.
Testimonial: "thank you very mucy "
SOURCE: CAN YOU RECOVER DELETED MESSAGES ON THE ANWERING
Once they're deleted they are gone forever. Sorry!
SOURCE: uniden dect 6
Since you declined to specify the model of your Uniden DECT 6.0 system, I can only suggest that you select it from the list beginning here to download a copy of the manual.
