Here are some steps you can follow to set a static wireless IP address for your Brother HL-2170 printer:
Press the "Menu" button on the printer's control panel.
Use the arrow keys to navigate to the "Network" option and press "OK".
Select "WLAN" and press "OK".
Select "Configure Network" and press "OK".
Select "Manual Setup" and press "OK".
Select "IP Address" and press "OK".
Use the numeric keypad to enter the desired IP address for your printer. Make sure to use a unique IP address that is not already in use on your network.
Press "OK" to save the changes.
Press the "Back" button until you return to the main menu.
Turn the printer off and on again to apply the new settings.
After following these steps, your printer should have a static IP address that will not change. You may need to update the settings on your computer or other devices to use the new IP address in order to print.
Fortinet can be unblocked using following points :-
Navigate to Ublocked Websites Proxy or Truly Unblock (see Resources). These proxies unblock filters originating from filtering platforms such as a Fortinet firewall. Your anonymity is also secure with these proxies because they hide your IP address behind their server.
Enter the Web address that is being blocked by Fortinet in the URL bar you'll find on the middle or bottom region of the page, depending on the proxy you chose to visit.
Click the "Surf" or "Go" tab showcased beside the URL bar. The website Fortinet was blocking will now be unblocked through the proxy's server. Your IP address will also be masked to keep your browsing anonymous.
click on the Network you are currently connected to
In the DNS field, replace the existing IPs with the unblock-us IPs, separated by commas: 208.122.23.22,208.122.23.23
Restart your iPad/iPhone to take into account the new parameters
with your iPad or iPhone's browser, go to unblock-us.com and make sure you log-in with the credentials they gave you for the free trial. The site should tell you if everything's alright at that point
You can use any proxy server to browse YouTube since it has been blocked in
your region (i.e Pakistan) . An external proxy server could mask your real IP address
with a fake IP address. Hence using an external proxy is the best
option for you to browse YouTube.com. You can ensure that your IP
address is masked by having an IP lookup from www.IP-Details.Com Good luck mate.
You need to setup a fixed IP address for this printer that no other users will use this address. Please follow the printer user manual in how to setup a fixed ip address. You will need to diable the DHCP ip address in your printer.
Secondly you will need to reserve this IP address in your router's DHCP server which corresponds to your printer's MAC address (a unique machine address code for each device). Please follow this properly in your router's user manual.
Thirdly please unblock the firewall settings in every PC that needs to use this printer. Usually this will be unblocked when you install the printer driver or program that comes with the printer.
Fourthly, please install this printer program properly that comes with this printer. You should detect this printer's fixed ip address during the process of the installation.
Please let us know any problem you may have in future.
You can follow some tips when you make the changes in the proxy settings
in Firefox. Obtaining your IP address is very important, and make sure
that you are not giving the IP address to outsiders. Follow the
instructions carefully; this will help you to make an easy change in the
settings. And after the changes, you would be using the 'Manual Proxy
Connection', so your details are not shared or traced by anyone on the
net. To change the setting to direct connection, turn off the proxy and
restart the settings. Now, you can make changes to the proxy setting.
This feature in Firefox has enabled many Firefox users to have a safe
and secure browsing.
There is no default IP address on HP printers with Jetdirect print server card. You set the IP address in the printer's network settings. The IP address need to be set to match your network's address range. To configure the HP network printer to work on your network, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559242-setting_up_hp_jetdirect_print_server_p
Use different IP address. Web community can offer you thousands of free IPs you can use as your own ones while surfing on your favorite blocked sites and letting you bypass any firewall and filtering software preventing you from unblocking Facebook at school. Do not forget to type this new IP in your web browser's address field if you really need to unblock Facebook at school in a fast way. Sometimes it happens so that you can use your own real IP address to unblock Facebook. To check if this is possible, open the command prompt on your school PC and type over there the following: "Ping facebook.com". Then you will see IP address, retype it in your browser's address field bar and if a system administrator didn't use Windows host services you may be lucky to reach a blocked site in such way.
