Rear wheel retaining/spring clip
SOURCE: broken harness on bugaboo frog
CONTACT BUGABOO
PHONE: 1-800-460-2922
E MAIL: [email protected]
WEB SITE: WWW.BUGABOO.COM
SOURCE: how do i remove front
The part of the front wheels that pokes out above the connection point has two slightly flared pieces. Squeeze them together and pull the wheel back through the connection point.
SOURCE: Harness replacement for bugaboo frog
Contact Bugaboo US customer service at 1-800-460-2922. They may be able to help you. Or check out their website at http://bugaboo.com
Hope that helps!
SOURCE: Bugaboo Frog Wheel Board
i'm sure you have solved this already, but yes, there should be two pieces that attach to the back axle that the board slides onto to attach it to the stroller. It wont work without these parts. The person you bought them from probably still has these parts attached to their stroller.
SOURCE: Bugaboo frog and wheeled board not fitting??
Had exactly same experience today. I emailed Bugaboo (via website) and got a reply the same day.
I attached the clips the wrong way round. The picture in the manual is not very clear....The little 'roofs' have to face each other and than you are able to push the clips further over the axle. The slot of the clip fits over where the small wheels comes in on the bar.
Hope this helps.
