Watches Logo
Zerubabel Ashine Posted on Oct 31, 2015
Nautica Clipper Analog #N15530G Watch for Men band
Delvi Rael Ramirez Romero
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 16, 2015
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
109
Points
NAUTICA BANDS ALLA MODELS
http://www.ebay.com/sch/bluss_929/m.html?item=221887033797&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
5 Related Answers
Anonymous
  • Posted on Nov 17, 2008
SOURCE: manual nautica watch
I cant aline de hands in 60 line both hands
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Jan 25, 2009
SOURCE: discolored white nautica watch band
If your watch band have UV sensitive pigmentation in it, there is nothing you can do, but buy the new band.
Find your nearest jeweller and ask to clean watch band in ultrasonic cleaner for 1 hour. If this kind of cleaning doesn't help, that means your watch band is UV sensitive and is and will be discolouring more and more by the time.
Alternatively you can try to clean it with the lighter fluid (ZIPPO). Soak a soft cloth in to lighter fluid and clean the band. Start with a small area inside band to make sure the fluid is not reacting as dissolver, as some resins react quite vigorously and tend to transform into chewing gum sort of state.
And again- if this cleaning doesn't help, the band is UV sensitive and discolouring is taking place.
That discolouring is happening becouse some of the colour pigments used in resin manufacture are sensitive to ultraviolet light and when exposed to sunlight or daylight, they react in a chemical
way, changing molecular structure, wich we see as the colour change.This process can not be reversed and this is why the band can not be cleaned.
Do not forget to rate please.
Anonymous
  • 2501 Answers
  • Posted on Jan 26, 2010
SOURCE: Where can I buy a new White Resin Nautica watch band.
If you go to the web site www.nauticawatches.com and select "service center" you will be able to see all the service centers. Choose your nearest and ask them.
Testimonial: "THANK YOU"
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Mar 04, 2010
SOURCE: replacement band for my nautica watch N17524G
Follow this link and contact Nautica: http://www.nautica.com/helpdesk/index.jsp?display=store&subdisplay=contact Rate me plz.
Testimonial: "excellent work ! thanks a lot !"
Anonymous
  • 19 Answers
  • Posted on May 24, 2010
SOURCE: How do I remove watch band links from m Stainless
I've got a great article that helped me out with this same problem! I thought this article explained things pretty well. http://hubpages.com/hub/How-to-Size-a-Watch
2answers
Nautica band links
NAUTICA REPLACMENT BAND http://www.ebay.com/sch/bluss_929/m.html?item=221597748969&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
Nautica replacement band for model A37003L
Nautica watch replacement strap N21500
NAUTICA BANDS http://www.ebay.com/sch/bluss_929/m.html?item=221597743576&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
Where do I buy a new bracelet to my nautica watch N12550?
Go to this link you can find many nautica bands
http://www.ebay.com/sch/bluss_929/m.html?item=221604999453&ssPageName=STRK%3AMESELX%3AIT&rt=nc&_trksid=p2047675.l2562
2answers
Hi , I need a leather band for my nautica a 23095
You can take any leather band but the wide must be 22mm. I´ve a diving band from casio watches since 4 Jears. It´s still ok.
1helpful
2answers
Can i buy a replacement metal wrist band for this watch? Model n19510
The only place you can get a replacement Nautica band is through Nautica. Here is a link to get you where you need to be:
http://www.nauticawatches.com/service
Best of luck to you.
5helpful
How do I remove watch band links from m Stainless Steel Nautica Watch? Model #A45001G
Nautica Chronograph Watch for Men-Instruction to set time & Date
hello
i have hour nautica ... number A29506.. i wants to change date ... please tell me how to chenge .. maybe you write in my e-mail
[email protected]
tthenks..
How is time and date adjusted
If the details says "stationary" then this means that the bezel does not move. This is typical in an inexpensive watch such as Nautica, and is probably just for "looks".
Top Nautica Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Nautica Watch Expert? Answer questions, earn points and help others
