When the tv is turned for the first time it shows the picture very good and colourful but as time goes on the picture changes to an almost black and white picture like its losing its colour. This stays for a few hours then it changes back again for a short while to show some colour then it slowly changes back again.
Hi Evan
Essentially it's a computer inside a modern Flat Screen TV these days. Not a lot that the average person can do...
But... if you feel capable of opening the back....
Once you get inside and check for loose or poor connectors,
I would be looking for leaky Electrolytic Capacitors.
Usually in the power supply section.
Look for brown fluid leaks on PCB & a very slightly puffed out or bowed top on the cap. (ready to explode)
Take a picture of suspect. Take note of Polarity (black stripe) & write down uf & voltage & temp values.
eg 1000uF @ 25v
To prove you are on the right track, you can connect a similar rated Cap across (in parallel) the existing Cap.
Depending on space etc. Even by short extension wires.
Power up & see results. Fault Gone or Not?
Then...
Unsolder & Remove suspect Cap & try to replace with higher voltage rating & slightly higher uf capacity depending on space available around the components.
Good Luck
See
How to Replace an Electrolytic Capacitor
It's a Vizio L37 Television
