Freeviewhttps://www.freeview.co.uk > tv-guide
The biggest shows live and on demand all for free with Freeview Play. find out more · BBC ONE Lon. Series 23: 40. Devon and Dorset. Escape to the Country · BBC ...
TVGuidehttps://www.tvguide.co.uk > mobile
TV Guide for all UK channels including Sky, Freeview, Virgin and Netflix. See what's on TV now and next and search for your favourite shows.
What you need to do is retune the TV, but when it is finished look at the regional settings. Or if the regional option is available before retuning, retune selecting your area so then you get normal BBC channels. It's likely that at the moment the channels for BBC are located at the very top end of the channel list say? - channel 800+.
You are clearly picking up signals from many transmitters. With regional settings you can change it to the area you live in.
But you will have to take into account how good your aerial is. Otherwise the signal quality will not be good on same transmitters. So the set may only suggest those with the best quality signals.
ITV stations might also change.
When done it will move the channels you mention to the top end of the guide, to 800+.
Note many HD channels have no regional options. For example here in Yorkshire we only get ITV Granada and not Yorkshire TV on the HD channel for ITV1. And BBC1HD does not show any programmes when local news comes on.
If your TV is tuned for Freeview, and you can pick up BBC 1, then you'll also be able to pick up BBC News. That's the 24 hrs news programme. It is on channel 130.
On your remote control, press 'menu'. Then select 'set up' on the screen. Then select 'Installation' on the screen. Then select 'Automatic channel scan' on the screen. The box should then scan for all channels, and with luck BBC will be included. If not, please repost. Some older Digihome PVR80s can't cope with the new multiplexing standard employed by digital freeview.
There is not a problem with the TV despite it's age this is can be due to your reception of the digital package for BBC. Have you checked through he full listings? sometimes the BBC channel will be at a different number setting because of the transmitter you are receiving. I assume you are using a digital box, you can enter a menu which will give you an indication of the strength & quality of the incoming signal. Do you pick up some of the other BBC channels such as BBC3 or CBBC? It's possible your aerial strength is a bit weak for the digital BBC package & you may need to have that looked at.
I have run into this problem a couple of times, once a loose connection at the LNB, other times it has been due to moisture build up (dew) in the loose connections, check all connections from the LNB through the tuner, and any other devices involved (a line map maybe?) that will most likely resolve the problem.
I think the point he is making is that he only has a universal remote - not the original, so the problem isn't not being able to find the channels, but not being able to select the retune option in the first place. I have same problem - the remotes that shipped with this TV were rubbish (I have gone through 2!) and some buttons stop working. The retune / setup memu is seperate to the other basic set-up stuff and many universal remotes don't have theis 'other' button. Best solution, get a replacement remote that is MADE to work with this TV then you can auto-tune to your hearts content.
