Sewing Machines Logo
amanda mcleod Posted on Oct 30, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sewing machine jammed with needle down and material can not be removed. Help I can break the needle, I really just want the fabric out.
Needle jammed down Help Need material out
R.A. Ellis
Level 3:
  • Singer Master 12,731 Answers
  • Posted on Oct 30, 2015
R.A. Ellis
Singer Master
Level 3:
Answers
12731
Questions
Helped
2615673
Points
59176
Usually, the needle & fabric will release if you are able to remove the bobbincase and the needleplate. You should probably try to do this to remove the broken needle tip, although usually it will drop out of the bobbin area and land somewhere in the bottom of the machine.
My machine is Janine 382. When I try to stitch , the bobbin thread does comes up but when I continue with the fabric, it gets jammed .and the upper thread breaks. It seems like it tries to take the fabric...
Hi, here are a few reasons it could be.1. use same thread in bobbin and needle.2. thread too old. 3. Cheaper thread frays and knots.
4.Thread and/or needle,incorrect size for the material sewn
5. Incorrect tension for the material sewn. And 6, thread tangled underneath feed dogs or bobbin. Hope this helps. :-)
My top tension is off. It was factory set for 5. I checked needle size, bobbin tension, thread, and for any build up of fuzz. I have a White Jeans machine. If I turn the top tension dial to 7, the bot
Sandra,
If the needle jams when sewing over thick items, it may be you have a dull needle? Not all machines can hem blue jean material without a hand to help the flywheel around, through the doubled over seams.
Additionally, when sewing the basic two pieces into one piece, start with the presser foot ON the fabric about a half inch sewing in reverse first, backing up to the fabrics edge and then proceeding forward through your fabric.
Fabrics too heavy or too light, are the common issues with home and commercial sewing machines.Knowing your machine and how to operate it; will get you through these "issues" when sewing.
Cheers, Happy New Year!
Kelly
Embroidery Services
San Diego, CA
Singer 8763 Needle Won't Go Up and Down
read the user manual and if you do not get anything from the trouble shooting section take it back for a warranty check as something may have moved from the material jam
1helpful
When I am sewing it will sew about 3 stiches and then jam.. It does it if I change weight of material or it will s kip stiches.
Skipped stitches is usually indication that needle is blunt or burred.
Or if you are using a sharp needle on knit fabrics it may also skip a little.
Not sure what you mean by "change weight of material" - do you mean you are sewing applique and going from one fabric weight onto another? or different sewing projects?
It is a good idea to change your needle for each new project (4-6 hours sewing time max) and choose the right type of needle and size for your project.
However, the jamming part sounds more like thread tension issues, especially if the jamming is happening underneath from the bobbin. If stitching is loose underneath, then top tension is the problem and visa versa.
Recheck your threading path, top and bottom tensions and that you have good quality thread. Change the needle, rewind a fresh bobbin, thread up and try again.
There is really good info on www.sewing.about.com or I refer to my Singer Sewing Machine textbook at lot too. Good luck.
I have a Husqvarna Viking (500) Sewing Machine. I jammed too much fabric in, causing the machine to jam. When I turned it on again, it worked EXCEPT the foot peddle is not responding at all! Could this...
Huskies are the Best! Please remove the feeder plate - under the needle, and look for any fabric still jammed. Remove any way you can - small screwdriver, nail-file. (It will take removing a small screw or two.) Unless you find metal parts, broken bits, you did not break anything. Removing bunched fabric should do it.
On the other hand, if you do find broken parts - Viking is Amazing! They can machine broken parts of sewing machines and guns, back before 1900! Love them! Just remove any parts related to where fabric cound be jammed, remove all you find, and try again.
2answers
3helpful
2answers
Sewing thick fabric and machine won't send it through
Sergers are not really meant to sew very thick material. The blades have a maximum amount of range, or thickness that they can reach to cut. If you go outside that range, get ready for a big repair bill! You can break loopers and even the needle plate when you "push" a serger. My advise would be to use you sewing machine for the, "pounding" work. The type of material matters too, A thick Quilt like fabric can be sewn becatuse it's not dense material. A thinner harder denim could max out at 3 layers because of it"s hard finish. If the fabric you're sewing isn't dense like, you could just need new knives.
1helpful
2answers
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Needle jams and breaks off
Needle jams....Thread is caught in the hook...solution...Remove the upper thread and bobbin case,turn the handwheel backwards and forwards by hand and remove the thread remands.
Needles breaks
1. Needles is damaged..Insert new needle
2. The needle is not correctly inserted....insert flat side towards the back
3. Wrong needle size for the fabric...Choose a needle to suit the thread and fabric.
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
