Hey Glenda - I understand that your Frigidaire Dryer (model #GLEQ2152EE0) has an error code "E68". After researching this concern, error code "E68" could potentially mean that your dryer has a problem with the heating element or the fuse. One thing you can try is to reset your appliance by flipping your circuit breaker for about five minutes. If this does not clear the error code, it would be a good idea to have a seasoned appliance tech check the resistance of the element to ensure its receiving the appropriate ohms. Hope this helps! -OOS
E68 for this model number says in manual that this is for a "button stuck" or held down for more than 30 seconds
ck all your buttons for one that just doesn't "feel right" when its pressed , this one will be your problem
Hi friends, I fixed my dryer some time ago by adding a 1/2 watt 10kohm resistor to the dryness button to ground as a pulldown to ground, usually read 19kohms in that input, after perform the button tests you will see that the dryness button is not working, and after soldering the resistor you just need to clear the error flag and will work as expected. any nore questions write to [email protected]
