Golf Logo
V
Victor Kelley Posted on Oct 28, 2015
Can a 36 volts motor work in a 48 volts cart?
5 Related Answers
Anonymous
  • 507 Answers
  • Posted on Oct 18, 2008
SOURCE: need a club car golf cart service manual
generic suggestion
http://www.blockbustergolfcarts.com/index.asp?Category=260&PageAction=VIEWCATS
http://www.lvssales.com/store/product.php?productid=13300
Anonymous
  • 15935 Answers
  • Posted on Jan 23, 2009
SOURCE: trying to power a amp with 16 volts. possible?
Golf carts do not have a charging system. If you are going to use battery power only, why not just add (1) 12V car battery instead of (2) 8V??
MA Audio runs (ran) their bench tests @ 17V. All the power ratings advertized are at 17V.
The power supply for the hk4000D is unregulated. So the more voltage = more power.. 8V-16VDC.
  • RMS Power @ 14.4V
    • 1800W x 1 @ 4 Ohm
    • 3600W x 1 @ 2 Ohm
  • RMS Power @ 17.0V
    • 2000W @ 4 Ohm
    • 4000W @ 2 Ohm
    More input voltage means the amplifier will have to work less hard to make power.
    Don't expect the amplifier to work for very long however. the current drain on a class D amplifier is huge. There are no on-board fuses protecting the power supplies, so be sure to have at lease a 150A power line fuse.
    With 150A current draw - even with the amplifier at 1/2 gain - expect to get 10.6 minutes of listening time from your 16 volts before recharging - also note, the amplifier MUST see 8V to turn on, there is a built-in voltage sensor that will shut down the amplifier if voltage is too low.
  • Anonymous
    • Posted on Jul 24, 2009
    SOURCE: 48 VOLT GOLF CART ''BATTERIES'' HELP !!! CURIOUS
    Sams club $77 each
    Anonymous
    • 4 Answers
    • Posted on Nov 12, 2009
    SOURCE: diagram of 36 volt hookup for trolling motor
    To get 36 volts, number batteries 1 thru 3. connect pos 2 to neg 1, connect pos 3 to neg 2, connect pos 1 to trolling motor controller and neg 3 to ground on trolling motor.
    This is only a solution for 3 battery system.
    For 4 battery system, connect 4 to 3 pos to pos and neg to neg.
    [email protected]
    Anonymous
    • 1082 Answers
    • Posted on Sep 24, 2010
    SOURCE: Trying to hook 12 volt lights to a 36 volt golf
    The exact answer depends on what battery voltage you have but this hint will get you going.
    Assuming you have 3 12v batteries, just wire to the first battery + - and you'll have 12 v. If you have 6 6v batteries, wire to the first + and the second -. If you have a voltage meter, you can verify the voltage of my suggestion.
    This will work for lights and other resistance circuits but not for sensitive items like radios.
    Golf cart batteries are series wired to get the higher voltage.
    If this answers your question, I'd appreciate 4 thumbs. I do this for fun and do not get paid.
    How to connect 4 12 volt batteries to Yamaha golf cart please
    It depends on the model, but they are usually wires in series to give 48 volts to the motors, so plus to minus on each them.
    Cart positive lead to batt 1 + the - to batt 2 + to batt 3 - to Batt 4 + and the minus - of batt 4 to the cart.
    Videos
    https://www.google.com/search?q=how+to+connect+4+12+volt+batteries+to+Yamaha+golf+cart
    You could also search make model manual
    Jan 27, 2023 • Golf
    Is it possible to speed up an electric golf cart?
    Most electric golf carts run on a max speed of 12MPH. It all depends on the voltage. The higher the voltage, the faster the speed. Most electric carts out there run on either a 36 or 48 volt operating system and can only last about 20-25 miles per each charge.
    There are some new carts coming to market that are able to travel faster and possibly on less energy and can go up to 19 MPH. Many of the latest models are operated by computers and have quite a few high quality and unique components compared to older trolleys and carts. If you want or need something faster, they are worth look into.
    Aug 17, 2018 • Golf
    Solenoid clicks. Why doesn't it go?
    Need to know what kind of cart you have. Ezgo, Club Car?
    36 volt, 48 volt ? for ezgo look at manuf. code, for club car serial number has the year. Then maybe we can figure out something.
    Sep 09, 2015 • Golf
    2answers
    How to get More power out of a EZ go golf cart
    I need to know whether it's a 36 or 48 volt cart. You can get a freedom chip for about five bucks that would give it more speed or torque depending on which you're looking for. If you have money to spend you could upgrade your controllers as well as your batteries as well as your battery cables. A thumbs up would be greatly appreciated if answer is helpful for your question. THANK you and GOD BLESS
    Sep 08, 2014 • Golf
    1helpful
    2answers
    36 volt ezgo
    First of all, lift rear axle off the ground and place blocks or jack stands underneath. Check to see if you have 36 volts On your batteries. Now you want to run a jumper across the big cables on the solenoid. Press the accelerator and the motor should engage. Clicking is a pretty sure sign that the solenoid is bad. Please let me know if this is useful. I can further elaborate more troubleshooting if this doesn't solve your problem.
    3answers
    Golf cart electric charged but wont run
    not enough info to even guess and I won't..
    May 19, 2014 • Golf
    I've bought (at auction) a Marketeer 36 volt electric truck (similar to what you see pulling luggage carts at airports). Before spending money to buy 6 new 6 volt batteries, I'd like to know whether the...
    I doubt your understanding of how the motor works is correct. More likely 2 of the terminals on the motor are for the field coils. The battery charger should not be used directly to power the motor without a battery also connected. The motor would function as a short circuit to the battery charger.
    Instead, you can use 2 car batteries to test if the motor works. The full 36 volts is not needed.
    Sep 16, 2013 • Dryers
    Want to connect electric lights to ez-go electric golf cart. It is a six battery system and I want to simply add a front light and rear red light.
    You said you have 6 batteries. Are they 6 volt or 8 volt? Hint-- 6 volt has three holes in the top and an 8 volt has 4 holes on top of the battery. Battery manufacturers recommend the use of a voltage reducer wired to the whole bank. This take the 36 or 48 volts down to 12 volts and is regulated. this is recommended so as not to stress just 2 batteries. If you have 6 volt batteries, you can use any 2 that are wired in series.
    48 volt GEM cart That will run fine in turf but not in road mode
    replace the voltage controller for the drive motor.
    Top Golf Experts
    Kardoc
    ADMIN Andrew
    ADMIN Andrew
    vince
    Are you a Golf Expert? Answer questions, earn points and help others
