I have a window that pops up everytime I go to my desk top. It says "Install Now" or "Install Later". It cannot be moved and it blocks the lower right hand corner of my screen across all apps. Regardless which button I hit, it stays. I think it's an Itune notice. Ideas on how to get rid of it -- permanently.
Install CCleaner and look at the startup items. You can disable them one at a time by double clicking on them until you find the culprit. http://www.piriform.com/ccleaner/download
you can't
you can help by installing a solid state hard drive
by removing as many desk top icons as possible
removing add-on and pop ups
by de-fraging the hard drive ( use device manager control )
by removing all non essential programs
adding an extra ram card if you only have one
best talk with a computer repair shop
Go in control panel click on Add or remove programs or programs and features Look for Bing Desktop or something like that. And double click it to uninstall.After the uninstall is done reboot the computer then it should be gone.
Most compaq PC's have a built in function to bring the PC back to it's factory state. This is stored on a small (hidden) partition on the hard disk and can be accessed by pressing F8 or F12 during bootup (before the windows splash screen). The menu option will be something along the lines of "repair your computer".
If you've changed hard drives, formatted, or deleted the partition, your only option will be to re-install windows using a windows disc.
Just borrow from someone an Windows install disk of the same type with the one you had and install it in your pc. The only other thing you will need is the personal Windows key - you will find it on the label stuck to the case of your pc. Later you might need to install some drivers - you will be notified if you must do that.
What specific error message/s does your computer prompt when you trying to install the wireless USB adapter? Since your running Windows XP you can skip on "run the CD first", try uninstalling all the componets for the adapter then restart the computer, when the computer is booted up properly insert the USB adapter(preferably used the USB port on the back of your desktop for maximum power). When the found new hardware wizard pops up, choose install software automatically(make sure that the setup CD for the USB adapter is already loaded on the CD-ROM drive then hit next.
If the installation proceeds click on finish a bubble should appear on the lower right hand side of your dekstop screen(syatem tray) prompting you that one or more wireless network is being detected, click the baloon and check if your network will show up on the list.
