Question about Sharp R-930AK Convection/Microwave Oven
Doesn't heat up, with turntable turning and lights on
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 3 Answers
I am NOT an expert but this sounds like a defective MAGNETRON. They go bad and then they fail to produce radiation. I have a R-9330 and the original magnetron went bad, and now the replacement is also defective. Everything else seems to be OK. Trick is finding the correct replacement magnetron. (see my post)
Posted on Jul 16, 2016
    New Friend:
  • 44 Answers
High voltage is blow due to over heatered..replace high high voltage fuse..
Posted on May 15, 2016
Anonymous
SOURCE:
Kenmore elite microwave model 721.79203010 problems
I'd check to make sure you don't have a door switch that isn't functioning properly. Also, might be a control panel or control panel interface issue.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Mar 18, 2013 | Microwave Ovens
GE Microwave JVM1540LM2CS Doesn't Heat
The turntable and the magnetron are two separate items and one should not impact the other. Since the other items are working it is doubtful that the fuse is bad. Also you need to know that the proper way to work on a microwave requires the use of special equipment to check for microwave leakage, it is not recommended to service them yourself.
Jan 22, 2018 | Microwave Ovens
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
Microwave turns on but no heat and turntable doesn't turn
It is one of two things, a defective door switch, "most likely" or the keypad control board is faulty.
Apr 22, 2012 | GE Spacemaker JVM1540 Microwave Oven
Turntable doesn't turn, no heat. Turntable cleaned, installed properly
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jul 28, 2011 | Dacor Microwave Ovens
Microwave is less than a year old. It looks like everything is working, timer, light, air, turntable, etc., but it doesn't cook.
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS
Jul 06, 2011 | Oster Microwave Ovens
While changing the light bulb on the bottom of Whirlpool MH1140XM, the bulb popped. I replaced it but now all I get is a hum whether I push timer, light or oven settings. The oven appears to be heating...
Hello, Thank You for using FixYa. I will be helping you today.Make sure no wires were pinched in the process. The turntable motor runs off the board that's why im thinking you have a grounded wire somewhere.
Thank You and please rate my answer if it was helpful..
Jun 19, 2011 | Whirlpool MH1140XM Microwave Oven
Microwave will not heat. The light comes on the turntable turns
Basic Microwave Oven TroubleshootingTips
heatman101/./,/,
May 16, 2010 | Maytag MMV4205 Microwave Oven
GE Spacemaker XL1800
have a GE xl1800 microwave that is not heating the food. The lights work, turntable turns etc. all but no heat. Help this microwave is only 1 years old.
Nov 03, 2007 | Roper MHE14XKB Microwave Oven
Sharp R-930AK Convection/Microwave Oven Logo
142 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ekse
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
