There is a setting that turns this on or off. For that phone it may be called t9 or predictive. to turn it off you go the text entry screen press ABC (bottom left corner, push upper left button)....Scroll to any other option beside T-9 or Itap (that's the predictive text) then press okay.
From another forum:
You may choose the 'input method' between 'Moto Input Method' and 'Multi-touch Keyboard'. Please visit 'settings' followed by 'Language and Keyboard Settings' and choose the one which makes it easy for you.
Hi there: - Press "#" --Once for "Numbers" --Twice for "Wild Characters" --Three times for "Non-Predictive Text"
Also I suggest check this link, To switch to another text mode on RAZR watch chapter 11 of a HandBookLive RAZR v3 video http://tinyurl.com/cchrjk.
Hope this helps; also keep in mind that your
feedback is important and I`ll appreciate your time and consideration if
you leave some testimonial comment about this answer.
go to create message or write messages in your mobile. go to options and search for t9 dictionary or prediction option. after finding it choose off in that. thank you sir
try to rest your phone go to menu-settig-initial set up -master set up- enter 000000
if this doesnt solve the problem then your phone is factory defected so you need to turn it back. i beleive u have one year waranty
go to create a message, then press the - key, go into entry setup then change primary to TAP. this then enables the function you require.
Happy Texting
yes its in your setting on your phone look in your message box setup. if you cant find it Ill have did out my old razor and help you again. [email protected] email me if needed
Go to Messages -->Create-->SMS/EMS-->the message multiline appears . Now press the round button in the centre of directional keys, this will take you to message editor. Now go to Entry set up . In the Primary setup select TAP english and in the secondary set up select TAP English.
