Really bad but how we are supposed to help you? Find a shop where they sell parts for Zanussi ovens.
Most I can do for you is to provide you some websites selling parts for zanussi: ovens
Your oven model number is usually located on the rim of one of the oven doors or on the frame oaround a door. Some ranges with bottom drawers have the model number on the frame behind the drawer.
Here is a tip that I wrote about replaceing your glass....
DeBruce Polish is Odorless, Non-Toxic and non abrasive and perfect on
stainless steel, glass cook tops, polished granite marble and more.
DeBruce Polish is Odorless, Non-Toxic and Non Abrasive. DeBruce is
perfect on
We buy DeBruce at debrucepolish.com.
not a train smash, locate screws to seperate the two door halves to allow access to the inner glass. remove screws and plates holding the broken glass. clean then place new one in possition and tighten screws comfortably tight.(dont over do it).Reassemble door.
Inner or outer? you will have to take the door off, done by lowering door to full open postion and youll see a fold down flap at hinge, fold down and close door and lift. this will allow you to access screws easier. remove handle and four bottom screws. that will allow you to take off outer glass....there will be screws on inside to take out inner glass.
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it. 1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door. 2 Remove the outer screws , starting from lower side of the panel. 3Removethe
inner screws. Keep all set of screws ordered, and take note of theorder
you remove them. You will follow reverse order in reassembly. 4 the frame will be free now, 5 Remove the external glass panel and leave it in a safe place. 6 Replace the inner glass. 7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
"removed the door from the
oven by releasing clips attached to the door hinge -- very nicely
engineered. Removed about 6 philips head screws to allow the door
assembly to be taken apart for access to the glass. Lifted out the
broken glass, cleaned the inside of the door, installed the new glass,
reassembled the door (a two minute project), and reattached the door to
the oven. Cleaning the inside of the door"
"I removed the oven door by
lifting it off with the hinges. Disassembled the door parts one at time
making sure I remember where I removed the screws until I am able to
get to the broken glass. The most difficult part is making sure that
the insulation strip & the gasket stayed in place after I replaced
the broken glass & doing the reverse process of installing the
parts together. Relatively easy process as long as you remember where
the parts go. When in doubt, I had to refer to the pictorial of the
disassembled door shown on your website."
To replace the door glass do the following: 0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it. 1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door. 2 Remove the outer screws , starting from lower side of the panel. 3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly. 4 the frame will be free now, 5 Remove the external glass panel and leave it in a safe place. 6 Replace the inner glass. 7 Clean outer glass and metal door, re-assemble it and mount it back
You have 2 pieces of glass that are separated by a frame then sealed. What has happened the seal has been broken and thus allowing air and grease inside. You can take it apart but the grease will come back, or you can buy a repalcement glass and be done with it. The question is, do you want to go to the trouble of cleaning the glass (1-2 hours of disassembly and assembly) probably once every 2 months depending on how often you use the oven, or buy a new one and it will always be clean. One caution, cleaning the glass periodically weakens and flexes the metal frame or band thus making it harder to properly seat the glass.
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
