The receiver automatically pick the best configuration for the source audio. Most music is 2 channels being up-sampled to 4 channels. (Sub-out is separate.)
Please don't panic and think that there is anything wrong with your Yamaha receiver. A lot of people are having this problem with set top box reception. Time lag / phase differences caused by satellite transmission can make your Receivers digital decoders go nuts !!!.The working principal is too complex to explain on this page. I have had clients call up and say on some channels only one speaker works in a 5.1 setup !!!!.You noticed DD and DTS signals are working fine.
SW means sub woofer, not necessary means center speaker in all receivers. Instead of setting 5ch stereo, if you have 3 speakers. try to set "3channel" or "simulated". If you own more than 3 speakers, you may refer to the user´s manual to correctly wire them to get the full sound.
Do you listen to audio CDs via a CD player or DVD player? Pure audio CD is only 2-channel, so either TV or the DVD player is doing the mix to 5 channels. But you can choose the sound mode via remote - there should be modes like 5ch/7ch stereo, where the same signal is going to all speakers (I you this mode for listening to radio sometimes).
THE BEST SOUND IS WHAT SOUNDS BEST TO YOU, HOWEVER DO THIS:
1, USING THE SETUP MIC CONFIGURE YOUR DENON, PAGE 8 OF THE MANUAL. NEXT
2. RAISE THE REAR SPKR LEVELS, PAGE 46,47. NEXT
3. WHEN LISTENING TO AUDIO CD OR RADIO TRY THE 5 CH STEREO DSP MODE.
4. WHEN WATCHING A DVD USE DSP DOLBY PROLOGIC OR TRY 5CH STEREO IF THE MOVIE IS MOSTLY TALKING.
5, TRY 5CH STEREO WHEN WATCHING PROGRAMS WITH MOSTLY TALKING
Front panel button engaged for 5 or 7 channel operation? Also check front panel rear surround speakers button is engaged. Should get you back to 7.1 unless you have changed the rear surround speaker setup for a 2nd zone, also be sure you have a 7.1 DSP setting enabled.
There are two ways to get change the speaker config that I didn't see at first. One is the curved-line 'Speaker Menu Guide') button on the front of the remote below the wheel that toggles A, B, A+B. The other factor is to choose a Surround Parameter that doesn't send all the audio through the center channel - (keep pressing SIMU button on the back of the remote to cycle through some DSP profiles, I'm using the 5Ch Stereo).
set it on dolby digital mode not sterio mode should be differnt modes on a ch only use prologiic or spin the mode dial to doby digital on movie on direct tv wont be dobly fake suround more less but center should work change settings modes
