SOURCE: NewAir AF-350 is blowing water
water normally condenses in the evaporator .. this runs down to a pan that drains to the outside section of the air conditioner .. there it it used to help cool the condenser and overflow runs out a drain in the back ... your unit is not draining the water properly to the back section .. that is usually caused by the air conditioner being being mounted with its top tilted toward the inside ... it should be level or slightly tilted toward outside for proper drainage ... its also possible that paper or other debree has clogged the drains inside the unit from the front section going to the back section ..
