Jura Capresso Impressa E8 Espresso/Coffee Maker Logo
d
dustin lambert Posted on Oct 24, 2015
How to get rid of air lock in a Jura Impress E8?
It looks like I have air lock somewhere the system. There is no water In any of the hoses and the machine keeps saying "Open Tap" and when I do the pump runs much louder than usual trying to pull water from the tank but nothing gets pulled into the system. I have opened the tap probably 10 times now and no luck, its still not pulling water from the tank.
  • dustin lambert
    dustin lambert Oct 24, 2015
    I just found a solution incase anyone else finds themselves in the same situation. First filled the tank with warm water since it has less oxygen than cold water. Next, I disconnected the water house from the back of the water pump, this allowed the water to be gravity fed to the pump. I quickly reconnected it once the water started coming out of the house, thus insuring the line was free from air. I then ran the "Open Tap" cycle 2 more time then let the machine rest for about 15 minutes and let the warm water go to work. I tried it again and water is now flowing through the system like it should.
5 Related Answers
Anonymous
  • 60 Answers
  • Posted on Jul 12, 2009
SOURCE: open tap - filling system - close tap
Try using warm water in the watertank, important that the water is not too hot, it can cause leakage in the o-rings in the fluidsytem.
Repeat the procedure a few times, if nothing helps, turn off the machine and wait 1 hour and try again.
If you can`t get around this message, then the flowmeter needs to be changed.
Anonymous
  • 33 Answers
  • Posted on Feb 13, 2010
SOURCE: When turned on it will prompt "Open Tap" "Close Tab"
There are two possible causes. One is easy the other is hard. So try the easy one first. Remove the grinds tray completely, and place you hand in the cavity that it normally takes up. moving you hand slowly in, feel towards the top. you will find a little flap, past that flap there is the tamper and coffee filter at a slight angle. This may be blocked, so clean with a cloth.
If that does not solve the problem (and 90% of the time it does) then you may have a small spec of dust that is stuck in the water system, this needs to be flushed and cleaned. The best place to do that is with a Jura approved center. Unless you are technically minded. Your local Jura chaps sound like they need a k!$k up their behind
tbreeze47
Tom Carson
  • 3083 Answers
  • Posted on Dec 21, 2010
SOURCE: My Jura Impressa E8 displayed
Here is a solution from another tech here on FixYa, and perhaps it will help:
kbg49
  • Rank: Apprentice
  • Rating: 100%, 2 Votes
Instructions from Capresso:
-pull out the drawer
-look inside the unit where the drawer has been removed and look for a flap (it's really the first thing you see on the left side)
-without moving the flap, reach your hand under it and up until you feel a flat surface
-this surface will have grounds on it
-feel for screw in middle
-take paper towel and wipe off grounds
-repeat until paper towel is clean
-replace drawer and done!
-do this about once a? week to prevent this
Good luck, and hope this helps.
espressonist
espressonist
  • 1711 Answers
  • Posted on Jul 03, 2011
SOURCE: Every time I make a
The problem as you described is have to do with your vibration pump. Is a very popular problem with vabrating pumps. They work purfect but as soon litle air is trap at there exit valve which is consist from two springs and one small teflon ball then you have the problem you have described. Manytimes repeating the descaling progress can solve the problem and in other cases if you desasemble the vibrating pump and brush it out from scale deposits and water dirt and rust then again you can solve the problem. If both the above can not give any results then you need a new pump. Many times it worth the effort to replace the pump from the first time so you will avoid all the desconfort and have results at once.
Anonymous
  • 33 Answers
  • Posted on Sep 09, 2012
SOURCE: Display tap on Jura Impressa E75 say close tap, where is tap please
The tap is the dial on the left turn it, then it will turn the tap off. If it is repeating this then it may need to be decalcified.
Jura E8 decalcify message even though using filter. Scrolled through menu cannot find filter section. Do I decalcify? or how to get rid of message? Is there something wrong with the machine?
The filter does not remove minerals from the water, so the boiler builds up mineral deposits. Only way to slow that down is to use distilled water. Even then you will get msg periodically. YES, decalcify.
1helpful
Jura e8 is not syphoning the milk properly
Try another descale and flushing the system. Bits of scale may have blocked the nozzle or inlet hoses.
Can't get system fill message off jura impress z5
My guess would be that your water tank float is trapped.
The remidy would be to descale the watertank itself.
If you use the Calris filter cartridge. remove it before descaling with a mild commercially available descaler. Don't forget to rinse thorrowly afterwards and reinsert the filter. Always use cold water to fill the watertank.
Hope this helps
How do I fix our Jura Impress Z5 coffee machine. It says "System Fill"
Press the button to the right of the function wheel that should be lit, this will then purge air from the water pipes and fill the boilers, the unit should then operate as normal.
Need to find an instruction manual or DVD for the E8
These are available online if you search Jura Capresso . Foe E8 I suggest you call the Jura Service line at 1-800-220-5701 - they are fantastic at helping out
2answers
I have a Jura Capresso Impressa E8. Was working great....put in storage for a year, now water comes out of the bottom of the machine, and not the spouts. Tried cleaning with Duro solution to no avail. I s...
It may be the diaphragm pump controls for the law including seals. The diaphragm control is located on the pump output and adjusts the line pressure, thus the water flow more even and the pump noise quieter. Check if it is leaking from the front right corner, that is where the diaphragm pump control unit is. The seals may have degraded. Or it could be one of the water lines but I'd start there.
fuer-die-%3Cspan%20class=" spwrap?>Jura-Pumpe-inkl-Dichtungen::2896.html">http://www.juraprofi.de/Jura-Ersatzteile/Pumpe-Fluidsystem/Membranregler-fuer-die-Jura-Pumpe-inkl-Dichtungen::2896.html
8helpful
3answers
Impressa E8 water leak
Did anyone find an answer to this - sadly we have the same issue.
5helpful
3answers
Cleaning instructions for jura E8
I am not sure if you are referring to the standard clean that the E8 requests. If that is the case the instruction are to press the rinse button for 5 seconds, until it asks you to remove the tray, then follow the instruction on the screen (they are normally, rinse, rinse, add tablet (should be Jura one) - add to powder shoot, then the process runs through.
If you are talking about de-scale then you should us the Jura de-scale tablets, but vinegar and biccarb can also do the trick.
Jura Water Pump
Any luck yet.
Jura parts are hard to gain access to in the US. They'll offer to repair it all day long. But sell you parts.....not likely. There are some internet stores online in Europe that you may have to look at to get parts. Good luck and if you find a good store that will ship to the US, please let me know.
Mike
3answers
Jura capresso E8
Did it work before this?
Sometimes hard water can build up and cause blockages.
Try mixing hot water and white vinegar (50/50 mix) and try running it through the machine. If this works, run it through a few more times than run cold water through a couple times to get rid of the vinegar.
Good Luck.
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Sulejman Sulejmani
Sulejman Sulejmani
Grand Canyon Tech
Grand Canyon Tech
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
