I broke the end of the upholstery hose and bought a new one- but would like to know how to remove and replace the hose. Sammy
SOURCE: bissell 7901 proheat service manual
I took apart the cleaner to clean the parts that were dirty and I can't seem to put the roller back in. Any suggestions
SOURCE: Need to clean hose.
I filled a bowl with hot bleach water and sucked the water up. It cleaned the hose pretty well (along with the gunk that was stuck in the hand wand). Mine was filthy. It looked like it had mold growing in it. Then I ran several rounds of hot water through the hose. I alternated hot water & bleach. Did this about 8 times. It is not perfect, but it sure does look a lot better. 90% of the gunk is gone.
SOURCE: Re: model 3522-5 Bissell proforce bagged vacuum hoses clogged
Worked perfectly. Thanks, jade_greeney. We thought we were going to have to shell out $100+ for a new vacuum.
SOURCE: i took my Bissell Powersteamer Powerbrush Deep
Here's a picture of the tubing on the PowerSteamer from an overhead view. I hope this helps you putting the machine back together. I know personally how challenging this repair can be, this picture really was my Bible when I was putting back together the machine for the first time. If you have a question about a particular tube, please feel free to add a comment to the repair page, and I'll be more then happy to answer any follow up question that you may have. If this was helpful to you, please be so kind and follow the Fixya model and rate the repair helpful by clicking the 4 thumbs up icons in the top right hand corner. This is greatly appreciated.
Here's the picture for you:
Chris Jones
GoVacuum.com
SOURCE: Bissell spray to floor not operating. Spray to upholstery fine.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
urr
Try suctioning clean water from a sink or bucket with the attachment removed from the hose. If the attachment is clogged, soak in hot tap water for 30 minutes and clean the end with an old toothbrush.
Here's a link to locate a BISSELL Authorized Service Center if you continue to have problems.
