My hand wheel works fine manually turning backward, when turning forward it gets stuck
SOURCE: Hand wheel will turn backwards, but not forward
here is some troubleshooting
Download your manual.
manual
http://safemanuals.com/user-guide-instructions-owner-manual/SINGER/3116-_M
Ok I know that youve checked this, but I have to ask.
Pg 39
Check and make sure the reverse lever isnt engaged.
I'm looking at pg 27 and see you have a traditional bobbin casing (not a drop in) make sure your bobbin is wound well and the case is inserted correctly. (they are picky)
Change your needle make sure its in right and tight. (I have bent many a needle just slightly, and it causes huge issues with this particular type of bobbin casing)
Pg 35 gives a test for the bobbin tension. If your thread rolls, the tension is too loose, OR the case may have gotten damaged.
Lets see if this helped.
Good luck
