Mitsubishi WD-60735 Projection Television Logo
Vanesa McGuire Posted on Oct 21, 2015
How do I fix my Mitsubishi WD-60735 tv that has a red blinking light?
The tv was in the process of a dlp chip being replaced when in the process the cooling fan was broken. We ordered a fan and replaced it as well and now when the tv is plugged in the green light blinks for about 20 seconds and then the yellow lamp light and red status light blinks for about two seconds and then there is just the red blinking light.
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Sep 09, 2008
SOURCE: green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
http://servicemanuals.vstore.ca/
Anonymous
  • 16 Answers
  • Posted on Jun 26, 2009
SOURCE: WD-52525 - No picture, green status light then turns to red lamp
check the lamp
Anonymous
  • 64 Answers
  • Posted on Aug 01, 2009
SOURCE: mitsubishi 62" dlp wd-62525
The lamp is either defective, not connected properly to the wiring or plugs (careful alignment required on the two connections), wrong type bulb, or the front panel is not replaced properly to trigger the panel sense switch (lower right side of panel)
salt56
TV Doctor Repair Consult
  • 373 Answers
  • Posted on May 20, 2011
SOURCE: I replaced lamp on mitisubishi
Are you sure you installed the lamp properly and put the door back so the interlock switch is functioning. Sometimes installing the lamp will get slightly displaced and is not plugged up properly and will indicate a lamp blinking light.
Anonymous
  • 14553 Answers
  • Posted on Oct 26, 2012
SOURCE: wd-60737 mitsubishi blinking yellow status light ?
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
2answers
I have a mitsubishi dlp tv model wd 60738 and when i turn it on the power button blinks for a second and then it stops but no picture and after while turns off
Most likely you need to replace the projection bulb. You can find them online. DLP sets are famous - or infamous - for burning out the bulbs/lamps.
Tv won't power on anymore. i get a solid red light. why?
Solid red light means the lamp has failed. Try replacing the lamp first. Mitsubishi DLP TV Bulbs
These folks have the proper lamp you need and have a 6 month warranty
Dlp chip replacement
The Mitsubishi part number for the DMD is 276P595010
1910-6003 Does not look like a good part#
The correct part# 276P595010 Dlp 1910-6143W
www.aaatvservice.com
3helpful
2answers
We just replaced the DLP chip in our mitsubishi 1080P tv because we had white spots all over the screen. Now after replacing the DLP chip we have no picture at all but we have sound. Help?
Likely you either forgot to reattach your color wheel ribbon connector, or have it on upside down. It's the tiny ribbon cable behind your circuit board that will come off as you pull the board away from the DLP chip.
1helpful
2answers
Mitsubishi wd 60735 dlp tv red lamp light
A common issue and it may be your problem is dust and dirt inside the unit---the set intakes air from the front and exhausts it out the rear==I have seen several of these sets where removing rear cover and taking stthe set outside and blowing it with a air compressor clears the issue.
Fans and other critical items that get clogged or coated with a moderate amount of dust will cause this issue.
4helpful
Mitsubishi wd-60735 no picture and red lamp light stays on
you have a digitdl light processing (dlp) television, which uses a high-pressure mercury-vapor lamp. depending on the hours of usage,the lamp will last about 1-2 years. the red lamp most likely indicates the end of lamp life. the lamp will need to be replaced. the owners manual will have instructions on how to replace the lamp. you can order a lamp on line. i perfer a brand name lamp. follow the instruction carefullt. i found that the television needs to be unpluged for an extended amuont of time to completely reset the timers, at least an hour. i have an older model wd62525.
What Causes the white dots on a DLP Mitsubishi tv?
the white dots (sometimes you get black ones too) are caused by a faulty DLP chip. you can find the replacement for your TV at the following website:
http://www.shopjimmy.com/dlp-chips/
2helpful
Mitsubishi Wd 60735 will not turn on
replace the color wheel p/n 938P137010 MODULE-COLOR-WHEEL
13helpful
2answers
Developing white dots
white Dots appearing on Mitsubishi DLP 1080p. What causes this?
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
