True GDM-33-C Refrigerator Logo
Is it normal for a True Gdm 33 to run continuously? My unit runs all the time even at setting of 1. Please advice.
5 Related Answers
Anonymous
  • 79 Answers
  • Posted on Nov 10, 2009
SOURCE: True GDM 12 won't go over 57 degrees. Just got
All refrigeration equipment has some sort of temperature control, either a temperature control knob(1,2,3,4 or A,B,C,D settings) or the unit has a pressure control to control the box temperature. The pressure control would be in the bottom of the case with the compressor.
Anonymous
  • 274 Answers
  • Posted on Jul 26, 2010
SOURCE: True GDM-12 - Unit runs, but won't cool below 60 degrees,
Is it very hot out side the unit.recharging may not hurt is it cleaned the lint could be trapping the radiator were the coolan goes through to cool down try cleanning underneath before recharging
Anonymous
  • 906 Answers
  • Posted on Aug 03, 2010
SOURCE: GDM-41 Refrigerator: True GDM-41 Refrigerator getting too cold...
good day,
hope this link below will solve your problem.
ref
Anonymous
  • 135 Answers
  • Posted on Jan 09, 2011
SOURCE: True GDM 12 not cooling.
you should check the condensor first make sure it is not dirty. Inside and outside fan works.
Anonymous
  • 135 Answers
SOURCE: True Model GDM 10 Not
try to replacemen the relay
Having issues with my true GMD-41SL-54, fans blower is running but unit has stopped cooling. It stays a little over room temp but fans keep running. It started 2 days ago all of a sudden. It was working...
You have lost gas (hissing), you need a refrigeration engineer
GDM-41SL-54-HC-LD - Retail & Display ' True Manufacturing ...
www.truemfg.com > Glass-Door-Merchandisers > GDM...
GDM-41SL-54-HC-LD. Glass Door Merchandiser. Compare. Description, Product Specs, Files & Downloads, Product Video. The world's #1 manufacturer of ...
True GDM-41SL-54-HC-LD 47" 2 Sliding Glass Door ...
www.nellaonline.com > products > true-gdm-41sl-54-h...
True GDM-41SL-54-HC-LD 47" 2 Sliding Glass Door Merchandiser is designed with the highest quaity material ensuring long-lasting durability. The LED lighting ...
True GDM-10 started making loud noise AFTER door was slammed after getting something inside; checked inside fan was running slow. Noise sound like something stuck in motor.
without knowing age of unit, I suggest replacing the motor. Sounds like the armature is worn the bearings and is moving inside the windings of the motor. I would do that first before moving forward with any other repairs.
True GDM-33 refrigerator icing up around the condenser then defrosts leaking water all over the floor.
It could possibly be an issue with the thermostat not shutting off. I would set it at it's setting to see if it shuts off. If not replace the thermostat. Also check to see if the evaporator fans are running.
1988 true GDM 33 its 100+deg. in my shop. Refrigerator is only cooling to @44 deg. is that about normal for the outside temp?
The unit is probably not designed to work in an ambient temp that high, probably 90-95 would be as hot as the manufacturer was thinking, however the age of this unit probably means the compressor valves are not sealing quite as well as they used to. this can cause a unit to never pull down all the way to proper temp. get as much air circulating to the unit to help draw heat away
1helpful
True GDM 12 won't go over 57 degrees. Just got it,older model no T-Stat. Cleaned up last night did see some brown syrup looking stuff.I did wait about 8 - 10 hours before pluging in. The unit has been...
True gdm-33 icing up have to disconnect then works okay for acouple of days
2 things to check - Excessive moisture coming inside will cause frosting - Have it serviced and check proper door seals - the next thing to check, for frost free units, is the defrost timer and its components - no defrost cycle = frosting up.
2answers
True gdm-69
http://www.truemfg.com/pdf/InstallManuals/GDM/gdm_english.pdf
The above will take you to the installation manual for your unit. This is to make sure you have set up the unit to their specs.
There are multiple things that can cause a lack of cooling. Let's cover a few of them.
1: Make sure the condenser coil under the unit is clean. You have to be able to take a flashlight and see light through the coil and fins. Be sure unit is off when cleaning. Use vacuum, compressed air, or a long, stiff bristle brush and go with the fins direction so they do not bend over.
2: The termostat may be set wrong or is not working as designed. Look for the compressor and fan on the condenser to cycle off when temp is met and on when it gets too warm. If unit is running all the time, look for frozen up evap.
3: If evap is frozen up, no air can pass through so no cooling is taking place. Air can not go through a solid block of ice. Clear ice with warm water. Again, make sure unit is off first.
4: Door not sealing or closing all the way. Seal on door should have magnets that help seal them to the door frame.
5: Again, if unit is running all the time, as in #2 above, unit may be low on refrigerant (freon). If you suspect this to be the case, have a qualified tech do the repair. Make sure he locates and repairs the leak. Adding freon without the repair means he will be back to do it a second time. The system is a sealed one and you should not have to continually add freon.
Good Luck and hope this get you going.
I have a True GDM 33 model is it possible tochange the temperatur
If your cooler is constantly running too cold the thermostat is probably bad. I can hook yu up with a thermostat. ;) www.northeastcooling.com
True freezer gdm 35f to cold
you just have to change the temperature control. I recommend using a white rodgers part no. 1609-105 set the cut out to about 33 cut in at 38 or 39 you might have to set defrost time to less minutes about 5 or 6 if coils dosent frezze with the setting i gave you. the bulb of the temperature control can be placed on the border dof the difusser.
Top True Refrigerators Experts
ZJ Limited
ZJ Limited
Ngoro
Are you a True Refrigerator Expert? Answer questions, earn points and help others
